![]() | Home > Maintenance & Modifications > Rear speakers in a double cab |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
I saw some pics in this forum of a DC with speakers in the back ...
I'm also also looking for them ... but couldn't find... I believe that they were from a member from Cyprus with a light metalic grey 110 ... Anyone ? ![]() ....ah ... found it .... http://www.defender2.net/forum/topic3090.html last pic Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
Excellent - cheers. Wanted though to have something more substantial. The reason the fronts sound so light is that there is little accoustic control due to the backs being wide open. Just cutting headlining and mounting straight on will also give little control (I am sure they are adequate). I want to achieve something fuller. As said though, not base heavy, just a nice full range. cheers TC |
Well for me a pair of columns on the rear would be enough ...
![]() ![]() I just needed to know if there are any wirings pre instaled to the back of the truck ... or do I have to extend it myself ? And how dificult it is to remove the roof lining ?, or it is a simple job ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Mark_110DCPU Member Since: 26 Jul 2010 Location: West Sussex Posts: 78 ![]() ![]() ![]() |
Not my truck, but I believe Ben posts on here...
I quite like this position: ![]() Click image to enlarge Although, I have since put station wagon rear seats and mechanisms into mine to give me folding rear seats, so this doesn't quite work for me.... [:O|===|O:] 2001 110 TD5 Doublecab |
That looks very tidy. Would be good to have a view on sound quality. I imagine they would be a little muffled with the seat back in place. I guess it is always going to be compromised though....... |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 ![]() ![]() ![]() |
Just seen this thread and thought I’d reply with my install, although I have only 1 pic.....
I built on long MDF box with 4 compartments (1 for each speaker) the box sits on the two wheel boxes and is kept in position when the seats are bolted back as normal, it was a nightmare to make as the box was made thinner to fit to the 60 / 40 split. But I think it works very well as no extra space is taken up in the cab, they are high out of the way and you don’t have to cut anything out of the car. ![]() ![]() ![]() Click image to enlarge |
Was there any wiring to the rear of the truck or you had to extend it yourself from you radio/dashboard ... ? Regards
had to extend, although it seems my black DC was shorter than my silver DC
If I were going to the trouble of fitting decent speakers I would ignore the factory wiring and run a fresh set of better quality cables direct form the head unit. The factory stuff is almost single strand! (sufficient for morse code but not much else!) |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
Yep, that was my solution. It is a little muffled, but with a set of miss and tweeters in the dash and an active sub under the rear seat it produces quite a nice sound. In a DC there seems to be very few places to mount other than there or the headlining. 2002 Defender 110 DC |
This approach looks very tidy. There is a nice little void to fill in. Shame though that the speakers end up side onto the seat....hey ho, If I wanted a monster stereo system I would have bought a Corsa ![]() |
Have fitted the single 'inphase' 100w powered sub. Excellent improvement, not too much, just enough.
Only issue now is it is making the rear windows rattle! Was thinking of making some raised feet extensions for the cubby and mounting the sub underneath. Anyone tried this? Cheers TC |
TOPIC HIJACK !
![]() Hi ... Just bought a subwoofer and I'm thinking in installing it under the right rear passenger seat ... The best place I could find ... and the only place it fits ! It's a Clarion Slimline.... However I have a question ... or a few questions ! ![]() Also going to route the antena for the CB through the lining on to the outback console ... but that should be easy! Any recomendations are welcome! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
You do it first lrmaniac then I can copy
![]() 110 HCPU Tipper |
