Home > Td5 > Warning light for choke on my 2000 MY Td5 110
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Hello everyone, my 110 has an unused (amber) throttle choke warning light in the LED warning light cluster (obviously redundant and not used at it is not a petrol engine). It is located just below the TC light in the bottom right. Can anyone tell me which pins I would use on the back of the cluster to plug in a wire(s) to illuminate that LED warning?
I would like to use it as a visual warning for something else. There are several unused pins on the small multiplug on the back side of the warning cluster. I cannot determine which ones would be the correct pins to use from my electrical diagrams for my Td5. The manual only shows what is actually used Sad
Any assistance would be greatly appreciated. Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #613836 1st Apr 2017 6:45pm
roel
It's not simple pins with bulbs:
I had a small problem with mine giving strange lights
one plug disconnected:
I fixed this with a small bypass.
 Roel
2003 90 Td5 (2009-now)
Post #613840 1st Apr 2017 7:19pm
Martin
Site Admin
Apply a ground to pin 2 of the 16 pin connector to illuminate the choke symbol.
I've used the same symbol as a warning lamp for my diesel transfer pump (front to rear tank).
If you need to convert a positive feed to a ground use a relay or a transistor driver (I've done the latter).
Roel you do indeed need to bridge some pins on the panel to extinguish the ABS and brake fluid warning lights. This is done on the loom on factory cars.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #613862 1st Apr 2017 7:55pm
4RF RDS
Thanks Martin, I'll give that a try 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #613865 1st Apr 2017 8:05pm
4RF RDS
Martin.. been trying for a while. Never done this before, is this correct?
1967 MGB GT
Post #616328 12th Apr 2017 2:49pm
Martin
Site Admin
Yes, looks right to me Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #616440 12th Apr 2017 10:14pm
4RF RDS
Got it all working finally. Thanks for the assistance. Unfortunately later today I left my iPad on the front wing (using the diagram as a reference)... I went to the market and lost my tablet on the drive there. Sad I have my warning light but someone gained an iPad... LOL. Crappy day all in all.
1967 MGB GT
Post #616451 13th Apr 2017 1:22am
TechnoTurkey
2005 Defender 110 Td5 CSW Zambezi Silver
If you have iCloud on the iPad then you can log into iCloud.com from any computer and it will locate your iPad as soon as it connects to a wifi network (or instantly if you have a 4G sim in it).
Post #616465 13th Apr 2017 7:29am
4RF RDS
Thnaks, did that andset it up to wipe it as well. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #616533 13th Apr 2017 12:50pm
