- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > How should I go about flushing the power steering? |
Miggit
How should I go about flushing the power steering? | |
So I've got a shiny new steering box to go on the RRC, including a spare drop arm!! not going to get caught out there , and I need to flush the pump before the new box goes on. And in true Land Rover style it's a factory secret
Will allowing all the old oil drain from the system via the open pipes suffice? especially if I sacrifice some new fluid to flush it through.. of will this be an under power undertaking? RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI
12th Apr 2017 7:04pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
