Home > Td5 > ABS Sensors
miker
ABS Sensors
I have a 1999 TD5 with ABS. Currently not working, and the nanocom reports it as a wheel Speed sensor issue (OSF) Looking around prices on wheel speed sensors seem to be anywhere from 11.99 (but apparently not compatible with a TD5 defender) to 280!!!
Does anyone know for sure if there are any differences? they all look the same, and I thought that the same wabco ABS unit was used for many ages of defender?
Cheers!
Post #616189 11th Apr 2017 10:06pm
geobloke
Before you fork out unplug the sensor give it a good clean, reset the fault and see if that cures it. The connection is often to blame for faulty ABS faults.
Post #616203 12th Apr 2017 6:40am
excossack
A 99' TD5 with ABS?. Mine is a 99' and no ABS, guess mine was an early one. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #616208 12th Apr 2017 7:18am
geobloke
And mine is a 2003 without ABS... should have been a standard feature...
Post #616212 12th Apr 2017 7:32am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I had this fault with mine recently (2004 XS,) when the O/S lower swivel bearing fell apart, after some investigation I found that the sensor is simply a push fit through the middle of the upper swivel, the extra movement of the hub due to the lower bearing failure appears to have pushed the sensor to be up a little so that it gave a reduced output signal, (it needs to be very close to the toothed ring on the outer edge of the CV joint cup to work properly.)
I carefully pushed it down until it wouldn't go any further and then levered it back up by maybe half a mm or so.
Worked for me Thumbs Up
Edit to add; worn or misaligned wheel bearings can also cause the same fault.
Post #616243 12th Apr 2017 9:24am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
The simplest way to determine if its the wiring or plug (after you tap it down to no effect) or if its actually the sensor itself is to switch it with the other side. If the fault persists on the opposite side, it is the sensor. BTW if it is an original sensor for your 99 (like mine) you got your money's worth out of that one.
In the past two years I have gone through this for both fronts, and both times it was the sensor, not the plug, not the wiring, not the CV, not the bearings, not just a tap it down (though I checked all those). Just saying... Good luck.
http://www.brit-car.co.uk/product.php/2451..._def_xa_5a 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #616264 12th Apr 2017 10:35am
miker
It's a 110 County SW, and according to the original sales receipt it was a paid upgrade!
Worth a try! Wheel bearings are in good nick fortunately.
@ 4RF
I'm pretty certain it is original, I guess after 18 years and 190,000 miles I shouldn't grumble!! Although at ~60 for a new sensor, I won't lose any sleep!
Post #616315 12th Apr 2017 1:46pm
bankz5152
ABS & TC where both optional extras on the TD5 but standard on the XS models.
I had the same error on my 110, cleared it 2,000 miles later it hasnt returned. Though if it does need to be replaced I believe you can get a quality OEM one for around 80
Post #616323 12th Apr 2017 2:13pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
You can check the resistance of the sensor (disconnected) it should be 1 to 2 K ohms. Also you can check if the sensor is generating a voltage by using the AC range of the multimeter by jacking it up and spinning the wheel.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #616360 12th Apr 2017 5:06pm
Martin 01
Mine had the same fault.
Took it to local Indy & it came up as off side front sensor.
Had it replaced but fault still there afterwards.
It would be nice to rectify this problem.
Mine is a 2002 with abs/tc
Post #616369 12th Apr 2017 5:31pm
Green&Gold
England 2004 Defender 90 Td5 XS CSW Willow Green
ABS fault intermittent, will try the various suggestions, thanks
Thumbs Up
Post #616436 12th Apr 2017 10:08pm
