![]() | Home > Puma (Tdci) > Easy to fit oil pressure gauge? |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 ![]() ![]() |
nobody has fit an oil pressure gauge in a 2.2?
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I've fitted them before in different cars, it's not hard at all, usually all you do is fit a T piece on an oil line and then run a wire to the gauge.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
or screw a Tee into the oil pressure switch hole and screw the oil pressure switch and gauge sender/capilary tube into the other part of the tee.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
If oil pressure is presented at the OBP then buy an app and watch it on a tablet.
Sadly it isn't on a 2.4 so the Torque app doesn't pick it up Merlin |
