Home > Puma (Tdci) > scraping noise
claydiggermud
United Kingdom 2014 Defender 90 Puma 2.2 HT Tamar Blue
scraping noise
strange squeaking and grating noise when breaking hard at about 10mph only. also carries on for a bit after breaking any ideas please Sad
Post #615517 9th Apr 2017 1:58pm
ickle
pads worn out
stone in calliper
stone behind disc cover
wheel bearing gone...?
Post #615532 9th Apr 2017 2:54pm
claydiggermud
thanks i take a wheel off and have a gander
Post #615533 9th Apr 2017 2:57pm
zsd-puma
Drive it in reverse for 20 yards or so, if there is a stone in there then it might be enough to flick it back out again.
It could even be a splashguard broken and rubbing on the disc.
Im pretty sure the cause will be obvious once you get your head under there.
Post #615558 9th Apr 2017 5:01pm
I once thought a gearbox was fudged having a stone between the disc and guard before now.
It once happened on an A5 we had, a few wiggly reverse laps of an empty car park cured it.
Post #615565 9th Apr 2017 5:32pm
claydiggermud
Taken the pads out and it’s still the same so I think it’s to do with the drive shaft ? Sad
Post #779118 26th Jun 2019 3:45pm
Are the driveshaft splines lubed or do you have one piece at leat on the rear?
If check those wheel bearings whilst at it too.
I think most of us have had a stone in the brakes before! One I had years ago was a real sod to shift it really was involving interesting reversing moves as mentioned above! $W33T $0U7H3RN $UG4R
Post #779124 26th Jun 2019 4:14pm
Check the retainer springs and pins aren’t squeaking too, they’ve been known to do that. $W33T $0U7H3RN $UG4R
Post #779125 26th Jun 2019 4:15pm
claydiggermud
I think it’s the wheel bearing but unable to remove the nut, I have the big socket but won’t budge
Any suggestions I have sprayed penetrating oil on but the socket just slips of Sad
Post #779132 26th Jun 2019 5:32pm
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
you mean the big hub nut?? I usedan inpact driver to get mine off. making sure you've un flattened the locking bit on the nut first or you'll never get it off.
Post #779754 1st Jul 2019 2:53pm
