![]() | Home > For Sale & Wanted > [For Sale] Alive tune box |
90def Member Since: 11 Apr 2011 Location: bedfordshire Posts: 98 ![]() ![]() |
Alive tune box atric with lead £100 ono
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 ![]() ![]() ![]() |
The Atric box is the best DIY option for remapping
You buy a map from Alive, and can install and remove the map at your leisure/pleasure ![]() Not to be confused with a "plug and play" Tuning box ![]() |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
OK thanks, don't worry then, I would love to buy it, but don't really need a alive remap,
Sorry ![]() |
I am thinking of tuning my TDCI pick up (2.4), Would a proper ecu remap be better or would a plug and play tuning box be better?
Thanks ![]() |
Plug and play are
Leviathan Member Since: 24 Oct 2015 Location: Staffs Posts: 248 ![]() ![]() |
You have a pm 90def.
OK thanks
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Well worth it.
Alive Stage 1 approx 150hp, no mods required unless you go to a higher tune. This is an interface to flash a map onto the ECU or return to stabdard map. It also reads fault codes too. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Capt_Steve Member Since: 10 Jan 2012 Location: Ross on Wye Posts: 39 ![]() ![]() ![]() |
Does this only work on the 2.4?
Its on my 2.4 60 plate not sure if they are the same on a 2.2 .phil
Thanks mate, I will do some research and get back to you.
Cheers Steve |
Ask Gary @ Alive.
Williamraff Member Since: 19 Mar 2017 Location: Leeds Posts: 40 ![]() ![]() ![]() |
Will this work on a 2006 Td5?
Thanks, Will. |
