Home > Wheels & Tyres > Hutchinson Offset/wheel Question
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Ive been given two models to chose from of Hutchinson Beadlock Wheels.
1. 16x7 with a 0.734 (18.6mm) offset
2. 16x8 with a 0.0 offset
Will either of these work with a stock 110 set up? i.e. no lift
Thanks
Post #614735 5th Apr 2017 7:23pm
Depends on the size of tyre you plan to fit rather than just the wheel. Darren
Post #614783 5th Apr 2017 9:11pm
jst
The 8j would allow for a wider stance as they will take wider tyres Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #614821 6th Apr 2017 6:47am
leeds
We are running 255/85/16 BFG M/T on Hutchinson beadlockers on a 90 with standard suspension set up.
Can not remember offset but think it is 0
Suggest you contact Nakatanenga for advice.
Brendan
Post #614850 6th Apr 2017 8:46am
nakatanenga
Germany
8j sold out!
7J can be used with the usual tire sizes up to 255/85 without lift. WANTED:
SII or SIII in max 1.5k
Post #614877 6th Apr 2017 11:39am
jst
Wider rims take wider tyres as above, if you want wide stance get wide rims. If you want diff height clearance then fit same width to narrower rim. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #614912 6th Apr 2017 1:36pm
hank
I have 16x9 0 offset with 285 75 16 fitted to a completely standard 110... No issues.
Post #614919 6th Apr 2017 1:47pm
big110
thx all for the assist.
Post #615047 6th Apr 2017 10:43pm
