Home > Puma (Tdci) > Oil leakage inner seal rear axle stub, looking for part nr's
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Trying to find the right article nrs for the replacement of the inner seal. The workshop manual doesn't state a clear picture for the rear stub axle. It's for a 2008 puma.
So far i've found the following nr's
FTC3648 - GASKET STUB AXLE
SX110256M - SCREW M10 X 24MM HEX HEAD 6x
FTC5268G - OIL SEAL STUB AXLE DEFENDER
FTC861 - STUB AXLE BEARING DEFENDER
571752 - AXLE DRIVE FLANGE GASKET
FTC4785G - HUB OIL SEAL INNER
BX110095M - BOLT M10 X 45MM WITH ADHESIVE 5x
RFD100000G - HUB LOCKING NUT
I'am not sure if i need the following part, it might be for the front axle only???
FTC56 - THRUST RING CV JOINT
Am I missing something?
Grtz from Holland Jack a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #614667 5th Apr 2017 12:34pm
dorsetsmith
(FTC3650 - GASKET STUB AXLE) rear sub axle with ABS Hole
Thumbs Up
FTC56 - THRUST RING CV JOINT your right front axle only
Post #614701 5th Apr 2017 4:47pm
Tdi4
Thnx Thumbs Up Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #614731 5th Apr 2017 7:16pm
