Home > Puma (Tdci) > Knocking sound from rear undercarriage |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 550 |
You may want to take it back to the dealer as I guess your car should still be under warranty.
I had the same symptoms on my 90" a year or so ago, was a problem with the rear diff, it was eventually replaced under warranty and now knocking is gone. See this thread or this one as well, hope this helps... |
28th Feb 2011 3:22pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Diff, driveshaft flanges, A frame joint, trailing arm bushes etc., etc are all possibles but usually confined to high miles / older LR's. At only a year or two old it ought to still be under warranty. Steve.
28th Feb 2011 3:34pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 |
drive flanges? Also the MT82 gearbox makes a pretty loud bang when changing gears. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
28th Feb 2011 3:48pm |
reno Member Since: 17 Feb 2011 Location: Singapore Posts: 9 |
Had sent it to my local dealer for this issue and was told that the knocking sound was due to a faulty rear axle.... They refused to carry out the replacement of the faulty part because my warranty for the entire drivetrain and suspension system had been voided as i am using 33" mt tires and wheel spacers.... They claimed that these tires and spacers put additional stresses on the axles and drivetrain....
28th Feb 2011 4:15pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Found a video I didn't know I had...
Roll pin in the rear diff had worked itself loose... |
28th Feb 2011 5:41pm |
Thanks for all replies.... Think the rattle in the attached video is quite similar to what i have.... Will get my workshop mechanic to check for any loose roll pin in the rear diff... Hope this is the real source of the rattle....
28th Feb 2011 10:59pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
had my rear drive shafts and flanges replaced after reporting the same sound, thats on a 40 ,000 mile 110. also half a dozen upper shock bushes in that time, which can make a bit of a noice. |
1st Mar 2011 8:28am |
