Home > Maintenance & Modifications > Replacing the windscreen washer jet!
Zagato
Client had his blown off by car jet wash people, half of it sticking out but replacement part goes right through the bulkhead. Any easy solution, is it in two parts, can it be split without breaking it.
Post #614156 3rd Apr 2017 8:27am
geobloke
Hi Zagato. No easy way. The unit is a one part item.
Bad news: Dash off... Big Cry
Good news: Whilst there you might as well fit a second weasher jet and have 4x jets Thumbs Up
Post #614167 3rd Apr 2017 9:25am
isacs
There is a kit to replace just the head as it's a common problem, around £10. However you can just buy another complete head for half that, pull it apart and the push the new head back into the stalk sticking out. It does work, I've done it
Post #614170 3rd Apr 2017 9:29am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Also did mine by drilling out a new one.
See here... Thumbs Up
http://www.defender2.net/forum/topic5728.html 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #614171 3rd Apr 2017 9:30am
isacs
Post #614172 3rd Apr 2017 9:34am
geobloke
I confess I did not even know that kit existed...
I would still be tempted to add a second washer jet. But now you have a few options to go to your client with.
Post #614179 3rd Apr 2017 9:56am
You don't have to take the dash out on a Puma, you can access the in-the-cab-side of the jet if you remove just the centre panel, followed by the metal bracket that steadies the rear of the radio. Much quicker and easier than displacing the entire dash.
Post #614193 3rd Apr 2017 10:58am
zsd-puma
I agree with black wolf, i did the same on mine a few months ago.
I did try as some suggested and try pulling the jet apart to just replace the outide part, but it just snapped off.
Ideally you want a 2nd pair of hands to hold the jet while you do the nut up but i managed it with tape on the outside.
Post #614232 3rd Apr 2017 3:06pm
ericvv
Post #614263 3rd Apr 2017 5:53pm
Zagato
Thanks folks, thought I remembered it being talked about before. I will let the client take it to the local garage who did it before! I think they must have split it and fixed it back together again.
Post #614281 3rd Apr 2017 6:48pm
