![]() | Home > Puma (Tdci) > Puma bonnet and doors secured.....hopefully. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
![]() As I've said many times before to everyone and anyone. It needs to be put in the back of the mind that any security details discussed or put into the public domain can be used or viewed by thieves. That includes here, various FB groups etc etc. Personally I only discuss any security detail with site sponsors, or trusted friends that I know are genuine owners. Theieves pick up a lot of info, ideas and vulnerabities simply by people unknowingly discussing it online all over the place. Take Trackers for example, it was often discussed a common place to fit. It didn't take long for thieves to commonly check said location for Tracker in seconds. After all, would anyone discuss anywhere online his their house was most vulnerable to break in. Or say their door code for security entry of their home / business or alarm etc etc. It's often the unknown covert mods we do, that we do not knowingly discuss that trips them up. There are plenty that I know of that they certainly would not bargain on. ![]() ![]() ⛽️🛢️⚙️🧰💪 |
DrKaz Member Since: 05 Dec 2016 Location: West Yorkshire Posts: 13 ![]() ![]() ![]() |
Sorry but I don't think I've done anything wrong in posting this.
I have not revealed anything new here. These hinges are commonly being used but still have flaws. Many have mentioned araldite or equivalent in bolt heads. And the balbarian in the head has been around and is popular with the cyclist community. Finally tamper proof nuts are an easy purchase. I share so others can secure their vehicles too. There are several different hinges on the market and this helps those who are in the process of choosing one. DrKaz Last edited by DrKaz on 17th Jan 2017 6:44pm. Edited 2 times in total |
How do you get the ball bearings out of the door hinges to change them when the cheap steel pin that Landrover put them together with rots away? Ray
They can be drilled out.
I lubricate these pins regularly and have heard some who do so get many years out of them. This remains to be seen. DrKaz |
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 ![]() ![]() ![]() |
I agree |
I never said anyone did anything wrong, it was purely a reminder. WeWillWin🇬🇧🇺🇸
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17712 ![]() ![]() ![]() |
With considerable difficulty! Been there, done that! |
Yeah I thought that might be the case. I'd have thought just filling the head head with some kind of epoxy resin should stop anyone trying to nick the doors as it would take a while to dig it out before unbolting and if you need to remove the hinges it should only take half an hour with a dremel. Ray
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1776 ![]() ![]() ![]() |
I've decided that I'm sticking with my TD5. The bonnets don't seem to be desirable, and I remove mine for almost every maintenance job!
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2725 ![]() ![]() |
If you've filled the hinge with epoxy glue, how do you now open the bonnet?
No resin has been applied to the centres of the black inserts that house the pivoting bolts of the hinge. Resin application only to metal curl attached to the bulkhead and top of these black insert to prevent thieves from using a crowbar to lever the curl straight.
DrKaz Doctor during week, wannabe Mechanic at weekends! Land Rover Defender 2.2 2012- daily drive Austin Mini City 1989- weekend play toy Volvo XC90 D5 SE 2007 SOLD Audi TT 2.0 TDi Quattro 2008 SOLD BMW 5series 525d 2005 SOLD BMW Z3 2.0 1998 SOLD BMW 318ti 2002 SOLD Mitsubishi Shogun 3.0 TD 2000 SOLD Mazda MX5 1998 SOLD Suzuki Jimny 1.3 GLX 1999 SOLD Rover Metro 114 GTA 1996 - first car SOLD |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
A theif with a small fit in your pocket potable gas burner would be able to melt the glue and security heads are to widespread now to be of little value .....your best bet is to use one shear bolt per hinge side and hope you dont have to remove te doors anytime soon ......in reality how often do you need to remove the doors. I have thought of attaching a stainess steel cable covered in ss trunking between the inside of the door to the door frame via the electrial wire conduit .....its not infallable but it will slow the ![]() |
Good job DrKaz, good informative post for new and old owners, we can't stop them but we can slow them down. Every layer helps.
@nitram - interesting idea listing your layers ![]() |
About once every three years if you have genuine Landrover hinges, when the hinge pins deteriorate to the point of uselessness! ![]() |
