Home > Technical > transfer box seal name?
monk
United Kingdom 2000 Defender 110 Td5 DCPU Java Black (black Hood)
Hi fed up of searching as bit of confusion, whats the seal called that fits inside the transfer box where the shaft from gearbox slots inside?
Post #612702 27th Mar 2017 8:45pm
MK
ICV100000 Puma 110" SW
Post #612723 27th Mar 2017 9:23pm
monk
Great stuff MK, cheers for that, by anychance do you know what seal the gearbox side is and can that be changed easily when the old transfer box is dropped? Just im having a garage fit the disco box ive just got and was getting parts ready before taking it in, thought they could csnge gearbox shaft one if simple job, cheers
Post #612742 27th Mar 2017 10:12pm
MK
Not sure I understand. The above seal goes on the transfer box side towards the gearbox extension and seals the the input shaft into the tbox. Puma 110" SW
Post #612759 27th Mar 2017 11:29pm
Alien
Australia
Which gear box do you have?
I've just got one for a 6 speed Puma MT82 uses... LR005800
It isn't easy to get at due to the adaptor/spud shaft setup.
I have the seal in front of me as in the process of fitting an Ashcroft upgrade shaft. Cheers,
Kyle.
Post #612761 28th Mar 2017 12:08am
monk
Hey MK, yeah ive ordered the one you said for the transfer box but thought there was one on around the shaft on gearbox side , presumed so it was sealed with two seals on the shaft?
Alien pal got that many numbers codes in my head ha, its a 2000 td5 gearbox is it the r380?
Post #612838 28th Mar 2017 12:30pm
MK
On the tbox side is the same on both Td5 and 2.4 TDCi. As for the R380 I cannot help. Puma 110" SW
Post #612841 28th Mar 2017 12:33pm
