Home > Tdi > New shocks?
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
New shocks?
Mine are starting to look pretty ropey now, i'm running standard height brit part HD springs.
I quite like the look of the Koni but im open to suggestion?
Post #611125 21st Mar 2017 1:24pm
I'm a big fan of Koni shocks but, depending on what you're looking for, you could do a lot worse than fitting new standard ones. They're a good compromise that won't break the bank. Darren
Post #611243 21st Mar 2017 9:28pm
Kit
What's the main difference between the Koni and the standard shocks?
Post #611298 22nd Mar 2017 12:03am
Well, Koni's are gas filled and adjustable, so a much higher spec. This means they'll keep their performance longer if pressing on over rough terrain and can be tailored to suit more heavily laden vehicles, which is why I've used them in the past.
Standard shocks (Armstrong, or at least they used to be) are traditional oil filled and obviously have a fixed damping rate. If the vehicle were to be used seriously - hammering across a desert for hours on end, for example - then they'd eventually fade as they can't dissipate the heat build up as quickly. They're also about a third of the price of Koni's but they've been the standard weapon of choice by Land Rover for years so are tried and tested.
There are plenty of other options too, of course. Some swear by Bilsteins or Old Man Emu, for example.
It really depends on what you plan to use the vehicle for and your budget. Darren
Post #611324 22nd Mar 2017 8:33am
Kit
Well i'm probably not going to hammer it, so maybe i'll get some standard replacements.
Thanks for giving me the options though Thumbs Up
Post #611703 23rd Mar 2017 8:56pm
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
I have Koni Heavy Tracks fitted and if I'm honest I'm yet to feel the difference but I am driving in England where the roads are reasonably good. Unless you're driving for miles on really rough roads then standard ones are probably fine. I only fitted mine because every time a part fails I like to replace it with a really good quality part.
This springs will make the most difference to how the truck rides. 2009 2.4TDCi XS Utility Wagon.
Post #611710 23rd Mar 2017 9:19pm
Kit
Are Sachs or Kayaba shocks any good?
Post #611915 24th Mar 2017 8:19pm
I'd never heard of them before but apparently Kayaba is one of the world's largest shock absorber manufacturer and it also has the largest market share of concrete mixer trucks Confused Darren
Post #611964 24th Mar 2017 10:36pm
