![]() | Home > Off Topic > Would You |
Would You
![]() &NR=1&feature=fvwp Original Member Pie n Pea Club. 110 HCPU Tipper |
With just a bit of Dutch corage
![]() 2011MY 110 XS USW Black |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
![]() ![]() 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Somebody else posted up this link a couple o' months ago and I thought it was amazing then!
In answer to your question...In mine not a chance! However if there are any offers of a loan vehicle, a crash helmet and enough flow pack to fill the vehicle and still see out of the windscreen I'll give it a go!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I'd do it but not in mine
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Go on then, I like a challenge!
![]() ![]() Rebuilt 1996 black/white Defender 90 300 TDi |
As LorryMan said no worse than loading a truck dropping the first on to th hoops
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
No worries as they say Try putting steel tracked excavators up the ramps of low loaders that are narrower than you are !!!! any mistake and your off, seat belt ?? dont need one your arse cheeks hold on well enough !!! If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
