Home > Technical > OBD security
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
OBD security
Please tell me if I'm posting any info I shouldn't. I've thought about it and I'm pretty sure this is fine.
I've recently purchased and programmed a new key fob using the one shot programmer. I knew it was easy but it's quite shocking really, and it's got me thinking about OBD security. I've considered a few options but I've stumbled upon quite a simple and effective method.
The ecu can only have 4 fobs programmed to it, so in theory if you "occupy" those 4 with genuine keys of your own, no one can easily program another, thus removing the risk while keeping the OBD socket fully functioning and in its factory loctation.
What do you guys think, reasonable in theory? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #609833 16th Mar 2017 2:22pm
X4SKP
Hello meeerrrk
I'd say we're safe so far... Cool
Interesting observation...I've secured access to my OBDII, but your thinking may well be right.
The 10AS Alarm Information does appear to 'limit' the total number of Key Fobs to 4
Can't be that simple, can it... Question SKIP
Post #609844 16th Mar 2017 2:56pm
grafty99
It would stop people using the one shot programmers. However if they had a little more time and were correctly tooled then physical obd security would be better. And probably more cost effective than getting more fobs Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #609871 16th Mar 2017 6:03pm
zsd-puma
Programming 4 fobs wont have the effect you're after.
As you can just reprogram another fob which will make the car forget the 4 previously programmed.
It just means you can have up to 4 programmed at the same time, not the same 4 for eternity.
I thought about cutting the 16 pin OBD connector off of mine then replacing it with some sort of non-standard connector, i'd just then need to make a 16 pin to what ever adaptor harness for my IID tool.
Post #609911 16th Mar 2017 8:56pm
meeerrrk
Thanks ZSD, that isn't how I had understood it I must admit, but I know next to nothing about these systems so I will assume you know more than me.
I think I'll still make some OBD security , I like your idea of a non standard plug and patch loom, nice Smile My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #609958 16th Mar 2017 11:11pm
zsd-puma
I don't think a connector would even have to be 16 pin, as i don't think all 16 pins are fully populated.
Post #609963 16th Mar 2017 11:29pm
meeerrrk
That's correct only about 4 or 5 from Memory. It certainly isn't fully populated anyway. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #609964 16th Mar 2017 11:31pm
