![]() | Home > Technical > Reverse light switch |
I replaced the reverse light switch on my LT77 only last weekend, so this may help:
Old and new switch: ![]() Click image to enlarge Switch installed on rear of selector block, accessed through middle seatbox panel: ![]() Click image to enlarge The switch fitted to mine is the later version, which is quite expensive, although I found somebody on eBay with some new-old stock so only paid about �20. There is an earlier, and much cheaper version, but it requires a separate locking nut that doesn't generally come with the switch. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
Im sure when I was on eurocarpars the other day that if you put in your reg and look at a category something like 'switches' for the vehicle they sell and locally (to me at least) stock the reverse and brake light screw in switches and they were around �8
That'll be the older version, PRC2911, that looks like this:
![]() They can be had for under a fiver on eBay but, as I said, need a locking nut. They are marginally more tricky to set up. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1630 ![]() ![]() ![]() |
hi many thanks to you all and thank you for the excellent photo ive just been out and had a look under the middle seat box and seen where it screws in,there is a bolt in there at the moment
Miggit Member Since: 09 Mar 2017 Location: Milton Keynes Posts: 72 ![]() ![]() |
I've just had a look at the parts manual and it shows a blanking screw next to the filler plug, on the gearbox remote, it's very vague but a search of the part number shows it to be a 3/8 unc bolt... I suspect that's the one you're look for
![]() Click image to enlarge Item 27 is the blanking screw (bolt) and 28 is described as a filler plug for the LT77 Looking at LandRoverAnorak's picture you can see where the filler plug should be in the earlier version of the LT77 ![]() ML 270CDI |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I expect the switch has the same thread as the Mini one which has 3/8" UNC.
Lock Nut here; http://www.minispares.com/product/Classic/...AE191.aspx|Back%20to and switch is here; http://www.minispares.com/product/Classic/...witch.aspx|Back%20to%20search |
![]() ![]() I paid less than a fiver for an RRC reverse switch on the bay of fleas... delivered.. Although I must admit it didn't come with the locking nut which is critical to the set up... and the Range Rover switch is 6.3mm (1/4") spade terminals. RRC 2.4 TD... it's either a stretched 90 or shrunken 110!! ML 270CDI |
That Mini one isn't the correct switch but the lock nut is useful if you want to use PRC2911 shown above. Darren
I'm sure that I've got a 3/8 unc nut in the shed if it's any help! RRC 2.4 TD... it's either a stretched 90 or shrunken 110!!
ML 270CDI |
Hi thank you all very much for the information you've all given it's much appreciated,thank you miggit for you're kind offer,I've phoned and ordered the part from my local parts shop (Dingocroft) and they're delivering it tomorrow along with a pair of wolf door top to bottom seals as my drivers door is leaking through the seal badly,a oblong reverse light and a rocker cover gasket as its weeping a bit
I'd expect it still fits, although you'd have to cut off the bullets and put spade connectors on it. |
It's a half nut, but any decent fixings supplier should be able to get them. |
Yes I know it's a half nut, I changed my switch last week! But to be honest it was a pita to get the spanner on the half nut.. there is very little room for error, and as there is over half the thread exposed, a full nut will fit easily, and give you a bit more to aim at!
FYI I am only reporting my experiences changing the switch on an RRC, which from what I can tell has a different remote on the box, and is a bit more key hole surgery having removed the centre console.. the Defender looks really accessible ![]() ML 270CDI |
It might do, but why faff around when the correct one is available and cheaper? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
