![]() | Home > For Sale & Wanted > [For Sale] Exmoor quick release Land Rover boss kit |
JBC Member Since: 21 Apr 2013 Location: Rutland Posts: 155 ![]() |
If this fits a puma 2013 my I'll take it please?
Thanks Jon |
I have thought about this a bit more and changed my mind so it's still up for grabs.
Thanks Spectre Jon |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
Hi there,
do you know if this would fit an 06 TD5? cheers john 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 ![]() ![]() |
Hi guys,
Full info can be found below: http://www.exmoortrim.co.uk/new-quick-rele...s-kit.html |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I'm interested but im afraid im no more the wiser for looking at their website.
I have a 48 spline, which boss does this come with? |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
Second dibs if its 48 spline
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
I believe you also need a boss to fit this too if you look at the fitting instructions.
Hi guys,
As per the link: The boss kit fits between the steering wheel and the standard mounting boss when upgrading your steering wheel, it does NOT however fit a standard Land Rover steering wheel direct. When purchased with either a 36 or 48 spline boss or the new 2015 boss you can then use the quick release and it fits very easily. These kits are supplied with all the stainless bolt fittings and allen key and also allows for horn push if required. The diameter of the boss is 90mm and the mounting holes align with any Mountney or Exmoor Spline Boss. The width when installed and locked is 55mm which obviously does push the wheel closer to the driver but we have these in our vehicles without issue, especially when used with a 13” to 15” wheel. So can be used with a Momo steering wheel, Startech and a few others. |
Muddymelv 2017 Member Since: 05 Mar 2017 Location: Liverpool Posts: 13 ![]() ![]() ![]() |
Is this still available ill take it if it is E reg 90 200 blue
C Reg 90 200 white J reg disco 200 blue R reg disco 300 green 2002 90 td5 blue 2005 110 dc td5 black 55 d3 black 2003 110 csw silver |
Muddymelv 2017 - sent you a PM.
