![]() | Home > Maintenance & Modifications > Extended arches which don't require drilling/cutting? |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Those ones in your pic look like they'll need holes drilling?
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
I'd also like to know this. Seems most appear the same as terrafirma, flat dog, britpart wider arches that need drilling.
MPS sell something similar and some on eBay look like similar design.
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Sorry I wasn't being very clear, what I ment is that I would like to get something similar to the above pic which doesn't require cutting? |
i haven't seen any that don't. I read you can get rubber strips that can glue to existing arches which keeps it reasonably stock looking.
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
Keep meaning to post on this, I was in Iceland (country!) recently and saw some amazing vehicles. Among them were a number of Defenders with extended arches which looked very factory, no holes... Unfortunately never saw drivers so was not able to enquire as to supplier.
Will post up some pictures. |
Sounds promising
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 ![]() ![]() ![]() |
Can I ask why you don't want to drill? The definition of insanity is doing the same thing over and over again but expecting different results.
Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
The body is in really good condition and I like the idea of it being reverse-able if need be
factory looking wider arches without need to drill seems like a big gap in the market!
Here you go.
Wide ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Wider ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Widest] ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge And just because ![]() Click image to enlarge |
Spectre Member Since: 26 Jan 2016 Location: South East Posts: 228 ![]() ![]() |
Nice photos, however those are clearly raised and it seems like extensive body modifications!
Posted the white ones for interest but feel the blue is far more subtle
Even so, shows proof of concept. Really can't see why there are not more wide arches with hidden fixings. Regardless though, if you want really wide arches that look factory, they are available but have never seen them offered. |
Thanks for posting but they don't look like a standard fit
If anyones interested I found the arches from my original post: https://www.devon4x4.com/extra-wide-def-arch-kit-in-hdp.html |
