Home > Maintenance & Modifications > Extended Wheel arches back to Standard
barrowg
United Kingdom 1990 Defender 90 200 Tdi HT Corris Grey
Hi all,
bought my landy with extended wheel arches attached, but they don't really work with the size wheels I've got. seeing as its going to be more expensive to change the wheels I've decided to change the arches back to standard. to the:
http://www.lrparts.net/standard-defender-w...ately.html
has anyone done something like this before and know how easy it can be done?
Post #608404 10th Mar 2017 4:21pm
VeeTee
Netherlands
From the pic it seems there is a greater arch cut out in the body panels than standard, so it seems sensible to measure and compare to standard one first... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #608407 10th Mar 2017 4:38pm
If the metalwork has been cut then it's going to be very difficult. The front outer wings are relatively easy to replace but the rear tub sides are much more involved. Darren
Post #608412 10th Mar 2017 4:51pm
barrowg
i don't really want to replace all of the body work, so i guess i may just have to get bigger tyres to fit the arches better.
if the body has not been cut is it simple just to remove and rivet the holes where the arches have been removed?
Post #608432 10th Mar 2017 5:57pm
zsd-puma
you could just put rivets in the holes and paint the heads body colour. Only a Defender enthusiast would notice they weren't standard.
Post #608440 10th Mar 2017 6:12pm
VVS210
There will be holes left in the bodywork when you remove those horrible arches - why anyone fits them I don't know, they are hideous and wide wheels are only useful off road if you are on sand or soft ground...
Not sure whether bodywork needs to be cut away to fit them but guessing it might if the arches have been fitted to accommodate not only wider but also bigger diameter tyres - if they have then it won't just be the outer wings at the front that will need replacing but also the inner galvanised wing too I would imagine.
Refitting the standard wheel arches is fiddly but not too difficult providing the flanges on the bodywork with the holes in them are still all intact.
Good luck.
Post #608452 10th Mar 2017 6:39pm
barrowg
how can i tell if the body work has been cut?
feelings are mutual i hate them make it look all weird and off
Post #608479 10th Mar 2017 8:19pm
Have a look underneath. If the bodywork follows the line of the wide arches without a lip on the inside, then it's been cut. If the factory lip is still there, then you could get away with removing the wide arches and making good any extra holes. Darren
Post #608484 10th Mar 2017 8:37pm
Lancerdoc999
I think the old arches may have been cut back to allow the new ones to be fitted. If no old ones on then it leaves a gap in the wheel arch inside which unlikely as road spray would get into engine compartment. The new ones will have required holes to be drilled. I assume a pain to change/fill.
Get some wheels with more offset so they stick out more. You can then also change the stop bolts to increase your turning circle as a bonus. I have Challenger steel 5 spokes from 4x4 tyres. They are selling at £75 each. -25 offset.
You might need to invest in some chunkier tyres. Try eBay for part used or post on the wanted part of this site.
I get loads of dirt/mud/spray up the side of my landy and looking to go the other way and fit some wider arches.
Post #608521 11th Mar 2017 12:32am
barrowg
there is still a lip on the inside, that looks factory, so does this indicate that it hasn't been cut? almost at a 90 degree angle to the body work?
cheers
Post #608861 12th Mar 2017 1:17pm
grafty99
Sounds like the bodywork is intact. I would try removing one of the wide arches and take a picture to show us but it sounds like you'll be able to fit standard ones back on *phew* Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #608866 12th Mar 2017 1:52pm
Lancerdoc999
I need wider arches and was looking at these to stop spray constantly on the sides of my 110. My mind is not made up about which ones. Anyone know if there are 1-2 inch wider more stock looking arches around for sale?
Post #608974 12th Mar 2017 8:43pm
barrowg
Help Urgent!!
Can anyone help me out here please really need it. so story goes that i bought this 90 as my first car, not really knowing much about defenders at the time, but now I'm more experienced I've had a look at many more vehicles that id like mine to look more like. at the moment it has these awful extended wheel arches, which make the wheels look weird and the body a bit off. I'm almost done with this little project, but this is the last thing i want to get sorted. so if anyone can recommend that as i want to change the arches would it be best to go with matte arches or the gloss ones
if anyone has any other advice it would be appreciated
cheers
George
Pic for attention
Post #616838 14th Apr 2017 6:36pm
mk1collector
I'd try taking those ones off first and see if what your left with will allow standard arches to be refitted. Ray
My build thread
Post #616844 14th Apr 2017 7:14pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
As above ! Some previous owner probably had large tires fitted and cut the arches as well as extending them Shocked
Post #616855 14th Apr 2017 8:02pm
