![]() | Home > Tdi > Slave cylinder on 300tdi |
Depending what's wrong with it, assuming its a split boot you can buy a rebuild kit for them.
300tdi slave cylinder : FTC5202 Repair kit : STC2818 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Kst80 Member Since: 28 Aug 2016 Location: Essex Posts: 81 ![]() ![]() |
I looked at the kits but need it doing ASAP for a trip so thought I would just swap it and later maybe sort the old one for next time.
The part number I found was FTC5072, the FTC5202 is for the higher serial numbers....I think, this is what is confusing me. Cheers. |
Mine is a 98, the only difference I have seen is pushrods part numbers. Worst case of getting from a main dealer would be get both on a use or return and compare the two with your old one, take the unused one back and get the cash. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Sounds like a plan, cheers Mash
