Home > Maintenance & Modifications > Part numbers
Olsey
Australia
Part numbers
Hi all,
I hope someone can help me out to confirm two part numbers. I've searched the Microcat and come up with some numbers but photos online don't seem to match.
* Clips to holder the center instrument panel (e.g. The panel that holds the stereo and switches). The microcat has AFU2692 but the photos online look like a small white plastic part not the silver metal clip that helps the panel fit snugly into the dash. These clips are the ones that tend to fall behind the dash when removing the panel Evil or Very MadI'm looking to replace the ones I've lost, so I don't have to pull the dash off!
* Fuse block that sits behind the dash under the steering wheel. Microcat says HAM4301L but photos look like a piece of foam that only hold five fuses rather than the plastic fuse holder that holds 8-10 fuses. There's a spare space there to put an extra fuse block, therefore looking to source one.
Thanks in advance any help!
Cheers,
Tim
Post #606284 3rd Mar 2017 2:20am
PaulMc
HAM4301L is a foam block to hold spare fuses.
The fuse blocks aren't available from Land Rover as a spare part, only as part of the main harness.
However, Autosparks sell a 10-way fuse box kit that uses the same Lear (Grote and Hartmann) fuse block that Land Rover have used since the introduction of the TD5 Defender in 1999 -
http://www.autosparks.co.uk/electrical-com...-wire.html
You won't need the clip-on lid or the Aluminium mounting plate. Paul.
Post #606385 3rd Mar 2017 12:10pm
Olsey
Australia
Paul, thanks for your help!
Post #606816 5th Mar 2017 4:39am
