Home > Puma (Tdci) > How to repair the front air vent
dgardel
Italy
a new small hole...
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #605202 27th Feb 2017 9:32am
zsd-puma
I'm not sure what we're looking at here?
Are you asking how to repair it or have you managed to repair it?
These are just Ford parts, used on the Fiesta among others, dead easy to source second hand.
Post #605214 27th Feb 2017 11:11am
dgardel
Italy
Repaired! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #605233 27th Feb 2017 12:17pm
JOW240725
Do the vents just pull out or are they fixed in at all? I want to remove for painting the silver circle at some point. Thumbs Up James
Instagram @suffolk_rovers
Post #605234 27th Feb 2017 12:31pm
dgardel
Italy
Just pull out Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #605240 27th Feb 2017 12:44pm
mse
looks like something sugru was made for Mike
Post #605270 27th Feb 2017 3:04pm
Dreamweapon
Scotland 2008 Defender 110 Puma 2.4 HT Cairns Blue
@JOW240725,
I suppose it is a personal taste thing, I have spent the last few months getting rid of all silver on my 110, I have finally achieved the effect below.
'Every time you try and operate these weird black controls that are labeled in black on a black background, a little black light lights up in black to let you know you’ve done it.’
- Zaphod
Post #605743 1st Mar 2017 12:40pm
agentmulder
Kuwait
Ditto, I want to touch up the paint on the silver ring... (likely to black)
It aint coming off using my fingernails at the moment, so I carefully apply force on the outer rim with something like a flat blade driver until it pops?
Or is that going to break it? Solved the bowel problem, working on the consonants...
Post #605819 1st Mar 2017 7:08pm
JOW240725
dgardel wrote:
Just pull out
Thank you, I'll give it a try Thumbs Up
Won't be going black, just a different shade of grey Shocked Whistle Rolling with laughter Embarassed James
Post #605844 1st Mar 2017 7:59pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
There are three locating tangs. I had the dash centre pulled forward, got my hand in behind and pressed two in together and the vent came out easily. Pulling out the centre dash is pretty straightforward. Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #610215 17th Mar 2017 11:03pm
JOW240725 wrote:
dgardel wrote:
Just pull out
Should see the doctor about that. Shocked Rolling with laughter Whistle
Post #610217 17th Mar 2017 11:07pm
Stiff1
As ridiculous as it sounds, I wanted to paint up some additions on the interior in the same silver/ grey as is already in there. Once I started to try and identify the shade realised the vents are different to the instrument dials. Big Cry
In the end I matched in with the dials, they are the darker Land Rover Brunel colour suffixed with a 1 in the colour code.
So now the brighter silver vent rings are bugging my OCD and I will add that to the list.
Post #610225 17th Mar 2017 11:49pm
