Home > Tdi > 300tdi Overheating
Page 2 of 2 <12
jst
i run the X-Eng switch on two vehicles, had it in there since they first came out. out no problems works well. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #603897 22nd Feb 2017 12:33pm
jr1104
United Kingdom 1998 Defender 90 300 Tdi CSW Rioja Red
Good to know. This is likely a stupid question, but how would I wire the Kenlowe fan controller to the X-Eng switch? At the moment there are just two green wires going into the top hose for the current thermostatic switch. Is it a case of cutting those wires and connecting them to the X-Eng switch?
Thanks
Post #604009 22nd Feb 2017 8:37pm
ickle
On my 100" bitsa, I had an electric fan with a 'off' override and warning light when 'off' so when wading you could stop it running and either damaging itself or throwing water everywhere.
Keith
Post #604022 22nd Feb 2017 8:54pm
L110CDL
I got an override switch on my Kenlowe fan that if the thermo packs up i can switch it on and still go on my way, it has a light that comes on when on Thumbs Up
Just make sure that you check your fan is a single/dual speed fan, it should be on the thermo unit Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #604029 22nd Feb 2017 9:11pm
Bps
I used to carry a jumper wire just in case the thermostat packed in so it would remain on all the time.
I fitted a kenlow fan 7 months ago to mine with a bolt on bits thermostat, solid billet type and tbh I've not even wired it up yet and not had an issue with temp once in my 300tdi. It normally sits halfway and only increases slightly when running hard for a long time
Post #604048 22nd Feb 2017 9:59pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
I have No FAN AT ALL. been like that for years, never overheateat, [ even with 3 ton trailer on ]. I would flush your system, as these engines run cool.
Post #604355 23rd Feb 2017 9:17pm
jst
yes, cut the wires off and connect to two of the three pins on the x-eng switch. one pin is constant to the other two pins. of the other two pins one is 87 deg? IIRC and the other 92 deg i believe from memory. there ar einstructions with it which say which pin is which. you need two of them for one fan.
as above would be worth adding a three way switch so you can have off/X-Eng switch/on in my experience. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #604505 24th Feb 2017 1:29pm
jr1104
Great answer, thanks.
Last question, then I can hopefully get on with sorting this out! What's the internal diameter of the 300tdi radiator bottom hose? The X-Eng looks to be available in 25,34, and 38mm.
Post #605012 26th Feb 2017 6:41pm
dorsetsmith
Post #605017 26th Feb 2017 6:50pm
jst
38mm Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #605325 27th Feb 2017 7:30pm
Page 2 of 2 <12
