Home > Technical > Another bulkhead question. early and late TD5 diffences.
rodspink
The late TD5 bulkhead has an extra bracket which I think is for a wiper motor . Think it moved position.
Is it just a mater of cutting this off and redrilling the holes for the orignal or can i leave the bracket and buy the plastic cover and fit with my old dash.
Am I missing any other diffences.
Thanks.
Rod
Post #603278 20th Feb 2017 10:45am
Lotus_esprit_s1
Cut off the later wiper bracket.
You need to fit a couple of rivnuts for the wiper motor to fit in the original position
You also need to fit newer wiper wheel boxes, and fit a different gear wheel to the motor (£15 and dead easy)
make a cut out of the centre bracket which holds the dash to clear the wiper rack tube. Also modify the bracket slightly where it meets the dash.
Post #604258 23rd Feb 2017 6:52pm
excossack
There are some differences. See http://www.defender2.net/forum/topic49854.html for pics of my original 1999 bulkhead and the 2002 onwards bulkhead.
Wiper motor mount is one, there are some holes that needed blanking off, which if I had known I would have plated, welded and sprayed. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #604267 23rd Feb 2017 7:25pm
Lotus_esprit_s1
Also the very last td5 bulkheads made in 2015/16 are a strange amalgamation of td5 top half and Puma bottom. They have vents and bracketry for the late td5 dash but with Puma heater duct cutouts and Puma wiring loom holes
Post #604308 23rd Feb 2017 8:17pm
rodspink
Thanks guys much appreciated.
Rod
Post #604409 24th Feb 2017 6:55am
rodspink
Just checked pics of the new bulkhead. No extra holes so thats a big bonus.
Cheers again.
Rod
Post #604412 24th Feb 2017 7:33am
excossack
In the link I posted there should be a list of parts I purchased - maybe of use to you ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #604429 24th Feb 2017 9:11am
rodspink
Hi John.
Yeah I spotted that and its ace and much appreciated. Did you also change your wiper wheel boxes too.
Rod
Post #604484 24th Feb 2017 12:14pm
excossack
Glad its of help. I didn't swap the wiper boxes over, as I only did them about 12-18months ago....maybe I should have taken the chance to....but hey. 1999 Defender TD5 110
Regards
John M0VAZ
Post #604491 24th Feb 2017 12:52pm
