Home > Technical > Cable Routing
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Cable Routing
Been saving up for sometime & have just bought
D44 twin battery tray
Two odyssey PC1500t batteries
Britpart IBS split charge system.
Question is what's the best route from the dash to the u/s passenger battery compartment? There's a fair few & don't want to chop it about too much?
Thanks in advance.
Post #604290 23rd Feb 2017 8:00pm
mse
Depends the wire size and need (assuming a puma) without running along the gearbox tunnel you can get through the large grommets in the bulkhead its a royal arse of a job when i last did it Mike
Post #604316 23rd Feb 2017 8:29pm
Timcat
Yes, well spotted Puma 110. There's 4 wires 3 probably 1mm & one 2mm..
Post #604337 23rd Feb 2017 8:48pm
mse
I certainly 2, around 2 mm through the grommet, although you could cut it to make it a little easier. Mike
Post #604362 23rd Feb 2017 9:32pm
