Home > Td5 > ECU Fault codes.
excossack
ECU Fault codes.
While sorting out the immobiliser issue I decided to check engine faults as well. No MIL displayed;
EGR Blanked, no AC
9,6 EGR Inlet throttle open load
10,1 Air conditioning fan drive
10,3 Tachometer drive open load
10,4 Gearbox ABS drive open load
10,5 Air conditioning clutch drive
13,6 EGR Inlet throttle short circuit
14,1 Air conditioning fan drive
14,3 Tachometer drive open load
14,4 Gearbox / ABS drive open load
20,5 EGR valve stuck closed (logged)
Panic or not to panic!?!? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #604176 23rd Feb 2017 1:31pm
dorsetsmith
not to panic
Post #604180 23rd Feb 2017 1:38pm
excossack
Sound. Done. Cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #604181 23rd Feb 2017 1:41pm
bankz5152
Fine. Clear them all off, but check the EGR modulators are blanked off as well
Post #604187 23rd Feb 2017 2:01pm
