Home > Puma (Tdci) > Gap under doors
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Gap under doors
The front of the doors (bottom edge) has a hole (both sides) you can just about see daylight through.
A quick check reveals a rubber seal running along the bottom edge then a gap and a block of some spongey rubber stuff - we've had occasional damp patches in the passenger foot well but I put this down to water dripping in when you open the doors.
Is it worth sealing this gap and if so, how?! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #60402 21st Feb 2011 6:04pm
mse
Re: Gap under doors
you do know you own a defender...right Rolling with laughter Thumbs Up Whistle Mike
Post #60406 21st Feb 2011 6:13pm
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
It's the Land Rover response to water leaks around the windscreen... leak in/leak out Mr. Green
Post #60407 21st Feb 2011 6:15pm
mick
Rolling with laughter Its so you dont have to shoot a hole in the floor (clarkson style)when you go through a flood or have a leek Laughing
Post #60411 21st Feb 2011 6:41pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
There is a rubber block that is glued to the door to fill this gap, it soon falls off. The gap then sucks in water especially when the window is cracked open Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #60415 21st Feb 2011 6:56pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Put a bigger bit of foam in so when you close the door it squishes up and completely fills the gap. Always has to be done here otherwise you die of dust on unsealed roads. No it doesn't fall off not if you do it properly.
New Defenders come from the factory now with a gap you can see the road through. All of them. Should be sorted on the PDI.
Post #60419 21st Feb 2011 7:07pm
spudfan
Ireland
Is this not a safety mechanism to stop you suffocating in the hermetically sealed Defender? Very Happy 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #60423 21st Feb 2011 7:22pm
AndrewS
It lets the water out Thumbs Up
So dont seal it up Thumbs Up 130's have feeling's as well you know Smile
Post #60426 21st Feb 2011 7:31pm
spudfan
Ireland
Sure you don't mean the sweat when the heater is on? Laughing 1982 88" 2.25 diesel
Post #60429 21st Feb 2011 7:38pm
DefenderOfTheEarth
I see - it's a design "feature" then? Rolling with laughter Laughing
Oh well! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #60438 21st Feb 2011 8:05pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
That foam tape is always falling off on mine. It gets wet and just gives up the ghost. I've had the dealer replace it twice.
Couldn't one just plug the gap with silicone or something, like you would do in the bath?
Post #60439 21st Feb 2011 8:11pm
Zagato
It must make the air con work overtime Rolling Eyes
Post #60446 21st Feb 2011 8:59pm
dgardel
Italy
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #60489 21st Feb 2011 11:56pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Are you talking about the foam 'draught stopper' between the bottom sill and the floorpan, the blocks at the bottom corners of the doors?
Post #60681 23rd Feb 2011 1:46am
eutek
I am indeed. It seems that as soon as it gets wet, the adhesive loses it's grip and it falls out.
Post #60687 23rd Feb 2011 7:21am
