Home > In Car Electronics > Indicator problem 200Tdi |
Click image to enlarge |
19th Feb 2017 3:11pm |
mystery wire if its red/yellow wire its rear fog light
indicator LH side green/ red, RH side Green/ white and black to neg green / Purple stop light red / black LH side tail/ side light red/ orange RH side tail / side light All other lights are good. have you checked lamp holder |
19th Feb 2017 3:17pm |
Scott_Landy Member Since: 24 Aug 2015 Location: Cheshire Posts: 85 |
Thanks for that. I'll give the lamp holder another check. It's brand new but you never know. I'm working on the assumption it's most likely the rear as that is where the changes have been made.
19th Feb 2017 4:07pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
It could be the bulbs, my dad recently lost both headlight bulbs on his motorbike at exactly the same time. Luckily they were H4 so he flicked the loading lever and set the rear suspension to max height to ride home on main beam. So don't rule them out 2002 90 Td5 Station Wagon
19th Feb 2017 4:47pm |
