Home > Technical > Stainless/Ali Corrosion
mse
How much more improved is the situation with stainless fixing into aluminium? Is there any benefit to removing a stainless bolt into ali item to put buzzweld thread stuff on?
Reason for asking is i was fitting some bolts using the last of my buzzweld thread lock and noticed it had water in it, i dont think much got on the first 3 bolts as it seems to separate well, although compared to my new buzzweld threadlock the old stuff wasnt as good.
Anyway i used normal loctite threadlock on the remaining bolts instead and im toying with whether there is any benefit to remove the bolts just to fit a different type of liquid, albeit that buzzweld state a property is to stop bi-metalic corrosion?
To be honest i cant be bothered to strip everything to get the bolts but ill be less interested to fix corrosion in 5 years! hence asking the question Rolling Eyes Mike
Post #602760 18th Feb 2017 9:14am
Naka do a special thread paste to help prevent that which I have akways used.
Is that of any use? No Guts, No Glory.
Post #602796 18th Feb 2017 1:21pm
zsd-puma
The paste I got with my Naka bolt kit wasn't anything special. Just a load of aluminium grease sachets as supplied with some brake pad kits.
From my research The correct grease to use with ally/stainless is nickel grease. I bought a tub of the stuff on eBay for not very much and it'll last decades with amateur use.
But any grease that keeps the water out will stop them seizing together, it needs water to make the two metals react.
Post #602833 18th Feb 2017 3:42pm
mse
I bit the bullet as it was warm and put the buzweld stuff on...if it works its good stuff...im sure time will tell Mike
Post #602859 18th Feb 2017 6:53pm
Screbble
I'm sure Buzzweld stuff will help. Fingers crossed Thumbs Up
Clearly there are many products that offer some resistance to the well known galling, seizing and electrolytic issues, and there are many posts that provide experience-based recommendations. From what I've read, many only deal with either the galling or the electrolytic issues separately.
If you want a single solution that addresses all the known issues with stainless steel fittings and fixings in the Land Rover context, then Tef Gel is a cracking product BUT relatively expensive. Thumbs Up
That said, trial and error seems to be the way forward!
Best of luck. Thumbs Up
Post #602874 18th Feb 2017 8:07pm
mse
Thanks
The buzzweld stuff is supposed to specifically be good for this application
Although i read some articles that stainless will in itself be better than mild steel...then something else saying a loctite coating will probably have some properties too...trial and error is the order of the day - shame it takes years to be sure of a problem Mike
Post #602880 18th Feb 2017 8:14pm
Screbble
Although this is a very general and sweeping statement on my part given the wider context, I don't believe that stainless steel will be better than mild steel in every situation. Given the right (wrong) environmental conditions, stainless steel is certainly going to be potentially (pardon the pun) more problematic when proximate to aluminium. It also suffers from galling (cold welding) when you use stainless with stainless (e.g. nut/bolt). Obviously it has better corrosion resistance in isolation when compared to mild steel, but you do have to be careful when using it with aluminium (and in a context when tensile strength is important).
I did qualify this with the point that this is a general statement, and it is of course only one (subjective) opinion, but the best advice is to approach the use of stainless steel on a Landy with caution. Whistle
Personally I like using stainless steel and do so whenever I am able to do so appropriately. There are many, many grades of stainless steel to suit specific applications (e.g. high tensile, marine grade etc.) and as indicated previously there are also many, many pastes, compounds, greases and lubricants that will address the galling and electrolytic action.
The most important point to make I suppose is that we have so many experienced forum members Bow down , many of whom are marine engineers, and they can point us all in the right direction Thumbs Up
Having said all of that Wink I do hope your Buzzweld works! Thumbs Up
Post #602968 19th Feb 2017 8:44am
ericvv
I have seen the very early start of stainless into alu as well as stainless into mild steel problems. Quickly took corrective action as below. Strong believer in the qualities of Weicon, but that has no threadlock capacities of course.
Eric
http://www.defender2.net/forum/topic38216....mild+steel You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #602974 19th Feb 2017 8:56am
need4speed
I just use a bit of heatshrink where the thread passes through the Ali
Far more permanent barrier than any paste
Post #603745 21st Feb 2017 9:17pm
mse
thats a good idea...a bit like ptfe Mike
Post #603801 22nd Feb 2017 12:06am
Likeomg
any links on this tef gel and where to purchase?
Post #603805 22nd Feb 2017 12:28am
zsd-puma
Nylon washers probably help in some applications too.
Post #603819 22nd Feb 2017 5:14am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I used to use copper-slip on all fixings, especially with steel/alloy interfaces however after a bit of reading it seems that ceramic grease is preferable because it removes another metal from the equation.
Duralac is good however it tends to dry hard and the yellow is difficult to wipe off once dry.
Butyl pond liner cut to shape where panels are bolted to the chassis is another option Very Happy
Post #603898 22nd Feb 2017 12:35pm
mse
Seriously have a look at buzzweld stuff - its supposed to stop or hinder the corrosion
http://www.buzzweld.co.uk/anti-seize-threa...-97-p.html Mike
Post #603960 22nd Feb 2017 6:19pm
zsd-puma
I dont get it? You asked us if it was worth using buzweld, now you're telling us to? Neutral
Post #604004 22nd Feb 2017 8:30pm
