Home > In Car Electronics > ISO DIN Adapter |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Oops forgot photo of wiring......
Click image to enlarge |
15th Feb 2017 5:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Was there a small loom and that came with the HU? There should have been.
Male plug should plug in the back of your new HU. The other end should be a female ISO DIN socket. The male grey and brown plugs plug into this. (This is the LR's two plugs.) (Be sure to check that you use the right plugs corresponding to the socket. Primary power, ignition plug etc to the same and speaker connnetions to the same.) The loom section you have in the photo above needs to come off, leaving just the two male grey and brow plugs from the LR.[/s] KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Feb 2017 5:57pm |
Thanks Steve, this makes perfect sense.
So the short flying lead with the large ISO DIN female socket at one end is HU specific (Clarion in this case). Alas no lead was provide with the new Alpine HU I understand then that I require a short lead with the ISO DIN female plug at one end and an Alpine compatible plug at the other. I'll pop down to Halfords and see what they have in stock. I have seen something compatible on eBay but I'm an impatient so and so...... Fingers crossed. Thanks again Steve |
15th Feb 2017 6:06pm |
Yep, That's the jist.
Alpine male to ISO DIN female socket. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Feb 2017 6:14pm |
Without studying in great depth it looks like this one: CLICK HERE. KEEP CALM AND Drill ON
15th Feb 2017 6:23pm |
That looks exactly right Steve
Click image to enlarge Halfords had everything else but I shall review the eBay offering in more detail when I'm back home. Thanks for your help Steve |
15th Feb 2017 6:54pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
is it this one. if your a prime customer you could have it tomorrow...love amazon!
https://www.amazon.co.uk/Celsus-AHU3509-Al...+unit+lead Mike |
15th Feb 2017 7:40pm |
Cheers Mike - that's the blighter
If I hadn't been so trigger happy on eBay, I'd have used SWMBO's AP account to get it here pdq....... Still, I'm home alone on Saturday for once, so as long as it turns up on or before then, I'll be happy Sadly, amongst many other things, I'm looking forward to matching the ICE illumination with the Defender 'green' glow..... I must get out more |
15th Feb 2017 8:06pm |
No problem - lets you build up to the excitement!
(you could always AP it and cancel the other) Enjoy the matching colour glow (before it starts to get light) Mike |
15th Feb 2017 8:09pm |
Arrived, fitted and green
Must have been the easiest installation and set up I have ever experienced. The Clarion must have been a little bit tired as the sound is incomparable. I am very pleased. Thanks for your help folks Click image to enlarge |
18th Feb 2017 12:40pm |
Good job. KEEP CALM AND Drill ON
18th Feb 2017 1:19pm |
Cheers Steve - couldn't have done it without you
18th Feb 2017 7:55pm |
