Home > Puma (Tdci) > Tuned Pumas and egt's |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 |
Apologies as off topic, but the wing mirror arm looks far from standard....mind me asking what have you fitted there?
5th Feb 2017 3:28pm |
Baytown Member Since: 30 Jan 2016 Location: Cairns Australia Posts: 83 |
Hi mate, well spotted!
I have the extension arms and larger unbreakable (within reason) mirror heads. Mirrors are from Mud Stuff and longer arms are Bearmack (I think). Itow an off road caravan so need the wider mirrors. Best wishes. Ken. |
5th Feb 2017 6:24pm |
Manxie Member Since: 29 Oct 2016 Location: Isle Of Man Posts: 26 |
Hi Ken, I've also fitted a Redarc egt/boost gauge, really nice bit of kit, but I'm having trouble accessing the menu via the ignition off/on, did you have any issues?
16th Feb 2017 10:26pm |
G'day Manxie.
No, I have my gauges fitted with selector button that comes with each. I've programmed mine via those. Did you fit the little black button? That's a great Defender specific cup that you have mounted yours in. Who makes that?; Its very neat. Ken |
17th Feb 2017 10:07am |
The pod is actually just a cheap universal one, but it's just been shaped with a Dremal to fit and compliments the other round shapes there, ties in really well, especially as the gauge has the silver bezel, I also got the colour/dimmer control module to match the green, and I have a feeling it's something not right with that modal that's blocking the access to the menu function with the little black push button. Do you happen to remember what wires you used to connect power and dash earth? Do you have the colour/dimmer module? So far my recorded peaks have been 22psi and 650degC (sensor after turbo). Decat exhaust, Alisport intercooler, Nugget air kit and BAS remap.
19th Feb 2017 11:15am |
