![]() | Home > Puma (Tdci) > DIY Clutch change. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17706 ![]() ![]() ![]() |
Done it, not difficult, but do remember that you're lifting things heavy enough to cause life-changing injuries in an accident.
It is easiest to remove the transfer box first, then the gearbox, and essential if you're working with the vehicle on the ground (there's not enough height to get them out as a single unit). You won't regret buying a transmission jack, it makes the job so very much safer and easier. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The problem with transmission jacks is storage. I did look at getting a cradle for my Webber trolley jack but none of the cradles i found will fit the hole in my jack without modification.
Yep, a gearbox would definitely leave one with a headache if it landed on you. Engine crane with a 5t lifting strop should be fine though. |
Mine's behind the settee at the moment but fortunately SWMBO hasn't noticed yet!
