Home > Maintenance & Modifications > Any way to increase heat output from TD5 heated seats? |
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 |
I have the Exmoor heated seat pads. They are excellent.
25th Jan 2017 10:30pm |
Apologies this took so long Christian. Actually hope you have sorted this by now. Each pad (base or seat back) is showing a resistance of 3-4 ohms, so 6-8 ohms total measured from the connector under the seat base. Not as easy to get to the connectors as I first thought, this was my solution; Click image to enlarge Something that also occurred to the wife and i whilst chatting about the heated seats on a long cold journey the other week is that the heat emmited from the pads does seem to fluctuate. I assume that there must be a thermistor or thermocouple hiding away in the pads that controls the ouput and has an upper and lower limit. Perhaps this is the cause of your issues... |
16th Feb 2017 8:37am |
