Home > Puma (Tdci) > Rear door rubbing? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4674 |
Think it is just good old rust. Happened on my tdi aswell over time. 1982 88" 2.25 diesel
20th Feb 2011 5:59pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Can you see any bare metal rub marks on the door, that will tell you? Can't tell from the picture but if it is rubbing it's only a bit so you should be able to hang the door better!
20th Feb 2011 6:02pm |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
I had the same thing. I used a hammer to lightly tap it down/bend the strip as it was not perfectly flat. Problem solved.
21st Feb 2011 5:31am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Thanks all... I'll have a look later to see if the strip can't be seated better or the door hung better.
I did notice that one of the screw heads (the right-most one) one the screws that hold the strip down had snapped off. It was never fully screwed down, and whoever was installing it must've snapped the head off and left it. Nice. Good thing I noticed it now, and didn't discover by accident by cutting myself on it. |
21st Feb 2011 7:41am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2417 |
Agree: rust. You should have a look underneath it and I would claim to change under warranty Puma 110" SW
21st Feb 2011 8:17am |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
Mine suffered badly from this problem - more the steel plate being too high than the door being out of alignment. Replaced and better fitted plate under warranty and paint repaired on the door frame - BUT - the screws used in fitting are dome-headed, and I noticed recently that one near the opening side is catching on the door bottom.
So I think I'll be seeking more suitable fixings rather than going back to he dealers yet again (this isn't the only snag I've had over the past 2 years!!) 1953 80 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
23rd Feb 2011 5:57pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Just a side note having just seen the pic of that rusty sill trim: got a mail tonight from a guy at Redback 4x4 who makes replacement stainless steel sill trims for the tailgate and front doors for pre 1991 Defenders. He's about to start producing the same for current model Defenders. I've told him to let me know when they're ready as I definitely want a set.
I was contemplating folding up some stainless sheet on the bender at work as I couldn't find anything available commercially, but Looks like I won't have to now. Pete |
23rd Feb 2011 10:48pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
http://www.entreq.de/products/interior/laderaumschutzleisten.html http://www.entreq.de/products/interior/tureinstiegleisten.html |
23rd Feb 2011 11:59pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5037 |
First i thought this strip was galvernised...i wouldnt see the point of changing it from what it is...was fine on the 20yr old defender, you cant even see it with the door shut.
Just get the door to shut properly! Mike |
24th Feb 2011 12:03am |
Thanks for the Entreq links, I hadn't seen those products before, and at a couple of hundred euros plus shipping for the three trims I'd need, I don't think I will be seeing them!
I can buy a lot of A2 sheet for that. Regards Pete |
24th Feb 2011 12:05pm |
