Home > Puma (Tdci) > Puma tub question
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Puma tub question
Ok.. so being we don't have PUMA'S over here, I don't have much of a reference point for this. Of all the PUMA trucks I have seen, (online photos, at the factory, and in the UK while I was there) all of them have the stepped rear tub.
Recently I was told "Not all PUMA tubs are stepped, only 90 stationwagons and 110 stationwagons were stepped. All soft top and commercial hardtops had the std Td5 innerwings".
Is this so, what are the defining features of "commercial hardtop" compared to a "stationwagon" ? it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #602069 15th Feb 2017 7:51pm
Thon
I think that station wagons (90 and 110) that are fitted with rear fold-up forward facing seats have the stepped tubs, and in the case of the 110SW even if they aren't fitted (but could be). Commercials are never intended to be fitted with that type of seat,so have the conventional unstepped tub.
I believe that's the case but am happy to be corrected
Post #602072 15th Feb 2017 8:03pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Thon is correct.
Post #602074 15th Feb 2017 8:07pm
mse
When i started this i thought it would be an easier explanation...maybe not.
Basically any commercial van no seats, has square sides i think
Any seated commercial so the 110 with the seats in the back row 2 but not row 3, van or pick up, has the stepped tub again from memory Mike
Post #602075 15th Feb 2017 8:07pm
CDN38
Trying to figure out why there would be a stepped tub in a van though...Hmmm??
Post #602079 15th Feb 2017 8:13pm
dorsetsmith
lest cost, one tub fits all
Post #602083 15th Feb 2017 8:21pm
CDN38
I guess a stepped tub in a commercial vehicle would be a bit of a pain to deal with as far as an un-even surface for sticking things?
So essentially they were making 4 different types of tubs, 90 & 110 flat, 90 & 110 stepped. I would think flat would probably have been the easier / less expensive to manufacture. it's a Landrover thing...
Post #602090 15th Feb 2017 8:31pm
Martin
Site Admin
Tub types on Pumas:
90 stepped -> fitted to station wagons (seats and windows in rear)
110 5 door stepped -> fitted to station wagons (seats and windows in rear), utility station wagons (no seats or windows in rear), double cab
90 square -> van/soft top/pickup
110 3 door square -> van/soft top/pickup
110 HCPU -> different type altogether
130 HCPU -> ditto
Basically, if it is a 90 and came with seats in the back it got a stepped tub. If it's a 110 with 2 doors per side (CSW, USW, DC) it got a stepped tub.
Otherwise, square tub as per 1983-2006 Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #602093 15th Feb 2017 8:40pm
mse
Thats my point - those are the same beds as used in the station wagon - so stepped, thats the same as mine row 2 and a van rear - note it has row 2 of seats.
Im sure the version with no row 2 doesnt have the stepped tub...
 Mike
Post #602094 15th Feb 2017 8:43pm
Martin
Site Admin
That's not a van, it's a 110 Utility Station Wagon. The visible seats are row 2, and it is basically a CSW with no rear seats or windows. 2 doors per side.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #602095 15th Feb 2017 8:44pm
mk1collector
Our my15 110 double cab has stepped as per martins post. Ray
My build thread
Post #602104 15th Feb 2017 9:06pm
As Martin has said, all Puma 110s with 4 or 5 doors have the stepped tub, since there isn't a non-stepped version of this tub (the DC uses a modified version of the USW/CSW tub which has a front bulkhead, but it is derived from the SW one so is stepped). 2 and 3 door Puma 110s have square tubs (there is no stepped version of the long rear tub).
90s are more confusing since there are both square and stepped versions but their application is as noted above.
Post #602164 15th Feb 2017 10:41pm
CDN38
Martin wrote:
Tub types on Pumas:
130 HCPU -> ditto
Got it!
Thanks Martin. it's a Landrover thing...
Post #602175 15th Feb 2017 11:54pm
