Home > Puma (Tdci) > Defender rear recovery ring
Greg L
Scotland 2000 Defender 90 Td5 SW Epsom Green
Going to remove my towbar and fit a rear recovery ring, seen a few on eBay. Don't want to fit a NATO hitch but was wondering what rings are good and bad. Also do I need to fit a spreader plate on the nut side of crossmember, is the puma crossmembers threads tapped ?
Post #601910 14th Feb 2017 10:19pm
mick
Post #601914 14th Feb 2017 10:44pm
Puma rear crossmembers have threaded inserts fitted (ISO M12 Coarse Series thread (ie standard M12) if I remember correctly) and there is generally no room for nuts, spreader plates, etc in front of the crossmember due to the fuel tank.
If you are fitting a NATO 76mm pintle to the crossmember it is essential for safety to fit a plate between the crossmember and the pintle. This is perhaps unintuitive but is because the NATO pintle and lunette coupling can under certain circumstances cause massive bending loads on the pintle's mounting which will destroy the crossmember (it was not so much of a problem on earlier vehicles where the pintle bolted through, rather than to, the crossmember but could still happen).
For a recovery ring you probably won't need to worry about the plate since it is not possible to cause bending forces anything like as great.
Post #601942 15th Feb 2017 9:07am
Devon-Rover
Maybe just go down the route of the standard 3.5ton jaw from Dixon bate.
http://dixon-bate.co.uk/products/gb/jaws/1...coup-.html
It'll bolt straight on and do for just a recovery point, that is simple yet effective.
Post #602064 15th Feb 2017 7:22pm
Greg L
I do have a Dixon bate tow ball with pin hitch in garage off my old TD5 but I like the look of the hoop
Post #602149 15th Feb 2017 10:11pm
