![]() | Home > My Defender > An Anoraks Tdi Defender 90 |
Thanks
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10911 ![]() ![]() |
Agree with you there, great when its a " toy " no rush at all
Woo hoo, just picked up a Puma-era passenger door on eBay to replace my rusted original
![]() Just need a drivers door now ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Nice one LRA
As the weather has been dry for a couple of days, I made a start on replacing the rear lights. What was fitted was, I think, the originals and at 25 years old they were worn out. The bodies were so worn that the bulbs would pop out and lose connections at odd or awkward times. I'm replacing them with more modern plug-in versions but this does complicate the exercise as the holes in the bodywork need to be enlarged to 45mm diameter. This is done with a stepped cone cutter and is pretty brutal.
As most of the holes are in the steel corner cappings, the new cut edges need painting. This began with a quick blast of etch primer: ![]() Click image to enlarge I'm also replacing the original rectangular fog and reverse lights with 95mm NAS-style round ones, which meant more holes in the ali panels. Once dry, it was given a coat of Arles blue coach enamel and I took the opportunity to touch in some of the chips that revealed the previous pink paint, too: ![]() Click image to enlarge Next job was to sort out the wiring. At it's most basic this meant adding Econseal connectors to the loom but I also spent some time removing redundant connections by replacing bullet connectors with solder and heat shrink, or Wago connectors for the multi-wire joints. I also removed a mass of excess wire. I've only done the nearside so far, which now looks like this: ![]() Click image to enlarge The original loom seems to include a nearside connection for a fog light, which will remain unused. The new number plate light is already fitted, with nice new stainless nuts and bolts, as it's using existing holes. Rather than fit some type of connector, I've just extended the fitted wires slightly and attached them to the appropriate Wago connectors. The final stage is to rationalise the wiring on the offside, which is more of a challenge as it includes all of the connections for the towing electrics: ![]() Click image to enlarge I also plan to swap the twin sockets for a single 13 pin one but that'll all have to wait until next weekend. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 6th Jul 2017 9:26pm. Edited 1 time in total |
Duplicate
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20678 ![]() ![]() |
Looking good, those little Wago connectors are good for what they are aren't they.
Pity they aren't waterproof too, although little point in that location. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Yeah, they're great for making multiple cable connections. When I get chance to drop into Screwfix, I'm going to pick up some of their 3 and 4-way push in connectors too, as they're pretty economic.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
In fits and starts between lousy weather and domestic duties, I've finally got all of my rear lights back together!
Following a trip to Screwfix for a selection of Wago connectors, I rationalised the wiring in the right hand cluster where the towing electrics were also connected. A couple of hours with a pair of snips and a wire stripper turned this: ![]() Click image to enlarge Into this: ![]() Click image to enlarge The towing electrics have been stripped out completely for the time being, as I plan to swap to a 13 pin socket anyway in due course, but the Wago connectors give me all of the spare ways needed to reconnect them. Today I installed the lights themselves, so the rear end now looks like this: ![]() Click image to enlarge I appreciate that that it doesn't look any different to most other 90's on here, but it represents hours of work! It's also a nice upgrade to the later round fog and reverse lights over the originals. Everything works as expected except the reverse light, which didn't work before I started. I suspect a fault with the switch but haven't had time to investigate that yet. Next job is to install Glyn Lewis cross member shields to protect all of my shiny new electrics - next weekend, all being well. Whilst I had the drill out, I also took the opportunity to install a nice alloy Land Rover badge: ![]() Click image to enlarge I've covered the back with self-adhesive 3mm foam and it's secured with M5 stainless screws and nuts, isolated with nylon washers at the rear. Progress, progress! Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 6th Jul 2017 7:44pm. Edited 1 time in total |
Today was spent trying to coax the reversing light into life but, as is often the way with Land Rovers, everything took longer than planned
![]() I started at the fuse box but taking the lid off revealed it to be full of dust. I started to clean it up with a brush but one thing led to another and I ended up stripping out the remnants of sound deadening and matting from the footwells and cleaning out all of the debris. Discovered a small rust hole in the side of the drivers footwell, but that's a job for another day ![]() Whilst stripping that lot out, I took out the door post trims where the door switches are mounted but when put back together I realised that the interior light wasn't working. I then spent ages cleaning, testing and fettling the switches but couldn't find anything wrong so, as a last resort, I checked the bulb. I found it loose in it's holder but then broke one of the connections of whilst poking and prodding ![]() So, with the light back on and the dirt cleaned up, I finally returned to the fusebox which, to paraphrase Eric Morecombe, had all the right fuses but not necessarily in the right order! ![]() Click image to enlarge A rummage in my toolbox found most of the ones that were required. Anyway, the fuse for the reverse light was fine, so attention turned to the switch. A bit of probing with the multimeter showed this to be dead. ![]() Click image to enlarge Unfortunately though, despite jumping the switch wires together, the reverse light still wouldn't work. There then followed much faffing around with the multimeter that revealed there to be a break in the wire leading between the two rear light clusters. I decided to split the loom in the centre where my not so mystery plug is located and a bit of probing of the wire narrowed down the break to the right hand side, so I spliced in a new wire for that section. I didn't have any matching green with brown tracer, so resorted to red, which was duly soldered in and protected with heat shrink. ![]() Click image to enlarge With the wire finally repaired, I then encased the entire loom and new wire between the clusters in some split spiral conduit. All I need now is a new switch ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 6th Jul 2017 7:38pm. Edited 1 time in total |
Great result there LRA, it always take longer
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Yeah, it's always been that way. I'll just be glad to get to the end of mundane repairs. Darren
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
LRA I can't help but notice you have no rear reflectors
![]() Great work on the back end though, really freshens it up ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I'd suggest the smaller stick on puma ones, they look smarter and have no screws to rust
![]() I have puma ones on my td5 to make it look more 'modern' at the back ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
