Home > Off Topic > Towing rules |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello mse
Do you mean... getting your 'full' licence parts B and E knowing if you need a type approved towing frame knowing your MRO (Mass Running Order) knowing your MAM (Maximum Authorised Mass) knowing your MPW (Maximum Permissible Weight) knowing your GVW (Gross Vehicle Weight) knowing your MTPLM (Maximum Technically Permitted Laden Mass) knowing you MPTW (Maximum Permissible Towing Mass) knowing what restrictions you have if your Trailer is Unbraked knowing the width rule changes in the UK (2010) knowing the towing speeds across Europe knowing the speed signs to be displayed in Europe knowing the rear lighting requirements in Europe or what rear view mirrors to fit... SKIP https://www.defender2.net/forum/topic83242.html |
13th Feb 2017 12:09am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
Before I went and passed my B+E, I could tow a heavier trailer behind my Seat ibiza than behind my defender....
Any questions?! |
13th Feb 2017 12:31am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
No I have my B+E and C and D1 - its the silly rules around C and all the combinations of trailers and how things arent thought through and then grandfather rights.
So crazy example, i can tow a plated C1 vehicle behind the defender...but i cant tow the defender behind the same C1 vehicle! There are many other madnesses, but thats the one that im ranting at!!!
Ignoring towing speeds but the 3050 UK unladen limit v the european 3.5t limit meaning in the UK some vehicles can drive faster than they can in Europe. Mike |
13th Feb 2017 4:50pm |
for Grandfather rights. Mind you I did start towing and driving H.G.V. artic units around a certain I.C.I. site at 17.
Thank God I don't have to deal with offences connected with towing anymore , gone are the days of towing anything as long as it was safe. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
13th Feb 2017 9:01pm |
Its got a little ridiculous - there isnt any logic to it either
Like the example above 7t is different to 7t - where one is less safe than the other, apparently. But then its ok for grandfather rights people to go to 8.25t, but not 12. I appreciate you need to draw the line somewhere...but the line could be consistent and clear but meaning different things Eg in the example above the +E could give 3.5t towing on all categories etc etc At the minute there are people with different types of +E entitlement - if i did my +E tomorrow, i found out i would be limited to (from memory) 3.5t and a 7 ton combination - but older +E's dont have that restriction - so you could couple the brakes and go higher Back to my c example 750kg on a car i get...but 750kg on a rigid is nothing and not sensible Mike |
13th Feb 2017 9:14pm |
