Home > Technical > TC light comes on when driving,especially when changing gear
johnnyd
Hi all
My TC light comes on occasionally when changing gear and an odd sound comes from somewhere, I can't quite work out where the noise is coming from, there is no ice/snow and its even coming on when driving in a straight line. Is this a serious problem, or something easily fixed? It seems to be getting worse, i.e. its happening more every week.
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #601183 12th Feb 2017 1:57pm
lb73
Wales
Had a similar issue on my works 57 110. Fortunately the garage managed to sort it by changing the brake fluid and it hasn't come on randomly since. They said that the abs modulator have a habit of playing up. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #601250 12th Feb 2017 6:19pm
Dieselhead
Mine does this when you turn hard left on cold mornings & sounds like the front drivers calliper coming on or a noise like AH AH AH Confused
Maybe its time for a brake fluid change as I do need to change my rear pads Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #601332 12th Feb 2017 8:44pm
A worn wheel bearing can sometimes cause this to happen. Darren
Post #601342 12th Feb 2017 9:19pm
Naks
or dirty ABS sensors --
Post #601394 13th Feb 2017 8:07am
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Try pushing the front ABS sensors in slightly
Post #601630 13th Feb 2017 9:48pm
