Home > Maintenance & Modifications > Turbo hose, check yours.
This is something IIRC Blackwolf on here suggested a while ago regarding 2.4 Pumas. Possibly the 2.2's as well?
(Anyone confirm?)
It's called the Turbo charge air cooler hose, circlip torque 3NM. (Not easy to get a Torque wrench in there though)
The hose tends to rub on the steering column just below and could cause failiure.
I've kept an eye on mine for a long time and there was just a coulple of mm clearance, fir this reason it wasn't an ultra urgent job.
However, yesterday I loostened the circlip and slipped the hose back up by around 3mm.
It seems to have slipped down a bit, causing it to be even closer to the steering colum.
Now, it's retightened and in correct positioning there is a better clearance.
I can see why it's perfectly possible that it could rub right through and cause failiure or even come off all together.
I'd take a look at yours. Thumbs Up
This I should how it should be. (Centre pic)
Below that you can see the close proximity of the steering colum to the lower edge of the hose, it's still close but acceptable.
 WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #600656 10th Feb 2017 2:01pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Had the same problem, picked up on mot on my 110 Puma. New hose fitted, and there was some reinforcement to clear the column. As you say, well worth looking at. One wife - livid
Post #600757 10th Feb 2017 8:29pm
I think there was a recall for 2.2's wasn't there? WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #600761 10th Feb 2017 8:39pm
ericvv
My two pressurized turbo/intercooler hoses were very well installed in Germany, they don't rub at all. And, I have opted for real German quality. Whistle
The recall was indeed for the 2.2. They have a turbo to intercooler hose which easily pops loose and could be cut by rubbing. The fix was essentially to install the very same rubber hose but reinforced by a metal spiral running around the hose.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #600766 10th Feb 2017 8:53pm
I wondered when you were going to join the thread Eric ... great bits of kit ... ask me how I know Whistle
Post #600769 10th Feb 2017 9:00pm
How do you know? Whistle Rolling with laughter WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #600783 10th Feb 2017 9:35pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
That is a nice bit of kit, Eric. Thumbs Up
BPman, so how do you know? Whistle 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT΄s,
Recaro CS΄s, anorak, wellingtons
Post #600787 10th Feb 2017 10:05pm
Pickles
The 2.2 recall also had a metal bracket to hold the hose in place.
Pickles.
Post #600805 10th Feb 2017 10:50pm
^^^^ Interesting. Did the 2.4 like mine ever have a recall too?
If there was I never got one. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #600825 10th Feb 2017 11:15pm
mick
Me neither
Post #600837 10th Feb 2017 11:37pm
No, the 2.4 never had a recall because, provided that the turbo-to-intercooler pipe is fitted correctly, there is no problem. It is sloppy installation which allows it to rub on other things.
Post #600856 11th Feb 2017 12:24am
Eric and I bought a couple of sets from entreq at the same time, yes they are expensive, but they are beautiful and practical.
Post #600866 11th Feb 2017 7:12am
ericvv
Post #600869 11th Feb 2017 7:23am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Could anyone please supply the recall number for the 2.2 and details?
Thanks in advance Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #600872 11th Feb 2017 7:51am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Bushpig, the info you're looking for is in this thread Thumbs Up
http://www.defender2.net/forum/topic30814.html 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #600874 11th Feb 2017 8:02am
