Home > In Car Electronics > Td5 max radio dimensions...?
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Hi,
I plan on getting a 1 DIN radio for my Td5, but I recall reading somewhere that space for the radio is limited. I am not sure if this was before or after the model update in 2002 (I have a MY2000). Is there anything I should look (out) for when ordering a radio (using the standard radio fascia)? Defender 130 HCPU Td5 MY2000
Post #600073 8th Feb 2017 12:03pm
bankz5152
Any standard din will fit. I had a Kenwood KIV-700 in my 90 with no problems, the space is only limited for double dins.
Post #600081 8th Feb 2017 12:29pm
RoadForce
Really? That's great! Defender 130 HCPU Td5 MY2000
Post #600082 8th Feb 2017 12:34pm
bankz5152
If yours is a 2000 then it is has the old dash, easy enough to pull your existing radio out to check!
If you want to double check im sure the measurements for the Kenwood KIV-700 are out there!
Post #600084 8th Feb 2017 12:45pm
RoadForce
Since I've had the car, it hasn't had a radio. Even the fascia is not fitted, but I should have it somewhere in the pile of spare parts... Defender 130 HCPU Td5 MY2000
Post #600085 8th Feb 2017 12:47pm
miker
I'd just go and get one of the shallow ones with no CD slot these days, save having to beaten up all the cables to make space
Post #600091 8th Feb 2017 1:20pm
