Home > Maintenance & Modifications > Any advice for removing paint overspray from a dash board?
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
As above, I have a plastic dash board section that has some paint over spray to it which I would like to clean up. Can anyone recommend the best stuff to clean off without damaging ?
Thanks
Post #598314 1st Feb 2017 6:05pm
ibexman
Non acetone nail varnish remover Thumbs Up
Post #598317 1st Feb 2017 6:17pm
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi,
If its on plastic I have used spectacle lens wipes and alcohol hand sanitiser in the past. However please test in an out of sight area first. A clay bar can help too.
If its glass or a polished/smooth non porous surface, try a very fine polish.
Hope it helps.
Post #598347 1st Feb 2017 7:38pm
williamthedog
Wd40 works well on a soft cloth Thumbs Up
Post #598354 1st Feb 2017 7:50pm
Rup90
I would use a decent clay bar - well lubed so it shouldn't stick.
Post #598439 1st Feb 2017 10:23pm
Depends very much if it's textured or smooth plastic? Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #598450 1st Feb 2017 11:06pm
