Home > Off Topic > Recommend a log splitter!
Zagato
I have been collecting free oak and chestnut logs today. Can anyone recommend a decent mechanical log splitter, presume it is better to split them green, especially the oak.... thanks.
I like the look of this, cheap, simple, less to go wrong no electrics and 10 tonne capacity.
Don,t think they do them in the UK however Sad
Post #597030 28th Jan 2017 6:01pm
Zagato
Seems this is regarded as one of the best.
Forest Master 10t Smart Manual Hydraulic Duocut Log Splitter for Both Vertical/ Horizontal Use
Produces 10 Tonnes of force
Duocut twin blades work together using two splitting blades rather than one to optimise the splitting capacity
Twin lever rapid lift jack for faster splitting with a 16mm-20mm lift per crank
Adjustable blade position so the blade starts splitting the log immediately
Can be used vertically or horizontally operated by foot pedal or hand lever
http://www.vigano.co.uk/proddetail.php?pro...GwodzksEiQ
Post #597039 28th Jan 2017 6:30pm
miker
I use a felling axe when camping, I plan to buy a splitting maul for the next time I go away, and a log bomb thingy for stubborn ones. Works well!
Post #597042 28th Jan 2017 6:33pm
Romadog
Shocked Shocked Shocked
Be quicker with an axe ??!
Used this that my neighbour had......saved a lot of effort. Thumbs Up
http://www.ryetec.net/product.php?id_product=70
Post #597045 28th Jan 2017 6:36pm
VeeTee
Netherlands
http://www.log-rover.co.uk Thumbs Up
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #597046 28th Jan 2017 6:38pm
nick345345
Scotland 2012 Defender 110 Puma 2.2 USW Baltic Blue
Not sure if you're interested in an electric one, but I've had a Al-Ko KHS5200 Electric-Powered Hydraulic Log-Splitter for a few years now. About £340 new. Had quite heavy domestic use without issue. Very well made. Having tried a few different models I'd definitely recommend one on a stand so you are working at waist height (for a horizontal splitter), saves back ache.
Post #597057 28th Jan 2017 7:01pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
If you have a lot of logs , perhaps hire one . Hydraulic splitter £35.00ish for a weekend
Post #597062 28th Jan 2017 7:13pm
Chopperone
I really wouldn't waste my money on a log splitter like that.
Electric ones are also very limiting.
I run a petrol 20 ton long travel log splitter ( will split upto 1.5m in length) & even that can be frustratingly slow at times.
Your best bet would be a leveraxe & whilst your are it get the book called Norwegian wood chopping stacking & drying wood....quite an interesting read.
Always split green.
Guy May your life be like toilet paper ; long & useful.
Post #597143 28th Jan 2017 10:36pm
Stacey007
Hello
I use this, it works well, very well half and hour to an hour using it.... you know your doing it Smile
but.... I'm sat here now, burner on and using free wood Smile
This isn't the same make as the one I have but the same the way it works.
http://www.ebay.co.uk/itm/Smart-Splitter-M...1937532718
Post #597148 28th Jan 2017 11:09pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
I have a Handy THLS6 plus, about £200 IIRC. If you look around you'll see it in various colours and called different things depending on who's selling it but it works well for me. I bought it after getting a load of wood in and, as good as my X27 is, I wanted an easier life Laughing
Post #597214 29th Jan 2017 10:18am
jst
Not to everyone's taste but we made one from old 3 point back hoe using PTO driven pump and bit of RSJ. total cost £250.
best to split green Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #597242 29th Jan 2017 12:01pm
Devon-Rover
We have a Clarke log splitter which is just another rebadged version of the one you post in your original post. that does for the difficult knotty bits that doesn't get hand split else wise all our firewood is done with a decent splitting axe and a good technique.
Without getting too nerdy about it when you put your log on the splitting block then making sure it is orientated. 99% will have a small split in the centre of the pith and splitting along this is going with the grain and makes it easy. this along with a good swing technique means you can go for hours without getting too knackered.
Post #597279 29th Jan 2017 1:31pm
Romadog
If you like living on the edge......
Post #597283 29th Jan 2017 1:46pm
dorsetsmith
very elf and safety Thumbs Up
Post #597285 29th Jan 2017 1:52pm
Zagato
Thanks folks, after all that I have just bought a log splitting axe with a hickory handle for £35 and it is just the job Thumbs Up
Post #597288 29th Jan 2017 1:57pm
