Home > Td5 > Is something missing from my Defender?
Gareth
If I look under the rear right hand wheel arch, and look at the back, I can see all the pipe work for the fuel filler, and a lot of wiring to do with the tow electrics is exposed. Is there supposed to be a cover for all this? As it exposed to the full force of any mud and water coming off the rear wheel.
I only spotted it today as I was jet washing the underside to get the salt off. Can get a photo tomorrow if it helps. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #596786 27th Jan 2017 5:18pm
There should be a plastic guard to cover the rear panel and wiring
Post #596787 27th Jan 2017 5:20pm
Gareth
Thought so Bow down
Does anyone have a part number? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #596788 27th Jan 2017 5:22pm
lightning
Post #596880 27th Jan 2017 9:49pm
They're them alright Thumbs Up
Post #596883 27th Jan 2017 9:57pm
roel
Behind that all mud will come together and make your chassis rot so I took mine out. Mr. Green Roel
2003 90 Td5 (2009-now)
Post #596978 28th Jan 2017 3:03pm
Gareth
Thanks, it's to keep the wiring dry. I can always remove it for proper cleaning. Rear crossmember is going to need replacing soon anyway. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #597022 28th Jan 2017 5:50pm
bankz5152
Neither of my landys (02 90 CSW, 04 110 XS) had any shielding there! I wouldn't worry about it getting wet, its generally all pretty waterproof.
Post #598607 2nd Feb 2017 3:25pm
