Home > In Car Electronics > Heated Rear Screen Wiring Route?
drinkdrinkdrop
Looking to add a HRW to my 2005 TD5 Van, I had found all the parts and was about to plan wiring it up from scratch but when I checked the fuse box it appears the fuses and relay are already present as is the connector behind the dash. The problem is I can't find a spot to tap into the white black wire that runs to the element. Does anyone know the route this wire takes to the rear?
Post #596736 27th Jan 2017 2:13pm
dorsetsmith
if you are going find the start of the white and black 1.5mm wire it will be in the centre fuse box see pic and ends see pic below
Post #596745 27th Jan 2017 2:57pm
drinkdrinkdrop
Re: Heated Rear Screen Wiring Route?
Thanks for that, that's currently my backup plan (running a new wire straight from the relay). My RAVE is for NAS spec so some of the colours/numbers are different, would you be able to screenshot the C0377-2 to C1760-2 connection and the C0704-1 to C1102-1 for me?
Post #596753 27th Jan 2017 3:29pm
drinkdrinkdrop
Beat me to it! it definitely doesn't make it to the 704-1 to 1102-1 connection, could you get a screenshot of the C0377-2 to C1760-2 connection?
Post #596754 27th Jan 2017 3:32pm
dorsetsmith
Post #596760 27th Jan 2017 3:52pm
drinkdrinkdrop
Perfect, Thanks alot Thumbs Up
Post #596761 27th Jan 2017 3:54pm
