![]() | Home > Technical > 2004 Defender TD5 - Hard to select first gear |
Replaced clutch at 97,000 miles 03 HT 90 same problems clutch plate 1/2 way to rivets but presser plate badly worn ware re-lace bearing works on it having replace clutch and flywheel all works good hot or cold good indicate is bit point high or low
