Home > In Car Electronics > Discreet reverse camera screen
Page 2 of 3 <123>
Green Machine
It seems that there are some single DIN head units now that will accept a video input. OK, the screen's not very big, but probably equivalent to the screen size in a rear view mirror solution. The other option I have wondered about is getting a bluetooth camera and then linking that to my phone, which would be especially viable for those who already use their phone for sat-nav etc. so it is already on the dash. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #596420 26th Jan 2017 1:56pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Can you get rear view wireless cameras that show the picture on your iPhone?
Post #596421 26th Jan 2017 1:57pm
blackwolf wrote:
LandRoverAnorak wrote:
As you haven't got a rear view mirror, is that not the ideal place to mount a screen instead?
An interesting idea, though it would have to be a fairly teeny screen. I will investigate.
A few years ago I bought the bits to install one in my old 110. I didn't get around to it in the end, but it was my intention to fix the screen to the stem of the RVM:
The screen is about 4 inches across and gave a perfectly useful view.
With a cunningly crafted bracket, it would be possible to mount a screen using the RVM mounting point. Darren
Post #596424 26th Jan 2017 2:07pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
In Discovery 2 I have small LCD (aprox 3,5") for reversing camera above the rear view mirror. And it works fine. I have it permanently on, not connected with the rear gear - for offroad use it is quite common to "reverse" downhill without changing gears, sometime also without touching the clutch pedal.
For night driving I just press button on the LCD to switch it off, because it shines a bit too much when it is dark. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #596426 26th Jan 2017 2:10pm
A 3.5" to 4" screen would be OK, I will look into this.
My Blackvue has front and rear cameras, and it is my intention (if I pursue the idea) to use the rear for reversing. The Blackvue does support bluetooth to a phone, but the time taken to set up and connect, and the issues of using a hand-held mobile make this impractical. (It might work if the phone was in a cradle and always connected, but it is way too much hassle to be a viable solution).
Post #596430 26th Jan 2017 2:22pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
The blackvue doesn't allow you to flip the view either horizontally or vertically though. An unforgivable omission in an expensive setup. V8 90...WIP
Post #596444 26th Jan 2017 3:55pm
Mud do a ball mount that replaces the Mirror mount Thumbs Up
Post #596445 26th Jan 2017 3:58pm
grafty99
How about one of these flip up screens. Could mount to the top of the dash or (if you can flip the image) on the roof.
https://www.google.co.uk/search?q=flip+up+...G0p-CHM%3A 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #596455 26th Jan 2017 4:45pm
dorsetsmith
Post #596464 26th Jan 2017 5:27pm
VeeTee
Netherlands
I mounted my 7" screen on the front of the cubbybox, details here... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #596472 26th Jan 2017 5:40pm
grafty99
That's a neat solution Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #596485 26th Jan 2017 6:11pm
Sulisuli
Garmin do a wireless reversing camera that links to some of their sat navs Thumbs Up I have one and its a clear enough image during the day, not stunning at night but still good. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #596487 26th Jan 2017 6:25pm
mse
My mirror one works really well Thumbs Up i would post a picture but ive not taken a photo of it Mike
Post #596612 27th Jan 2017 12:00am
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
This works well. Wired to reverse switch, camera in cross member next to tow bar. Once the rear window is tinted I might as well get rid of the mirror as I rarely use it at the moment. 2009 2.4TDCi XS Utility Wagon.
Post #596673 27th Jan 2017 10:33am
You may want to bear in mind that on a vehicle this recent, you must have an internal RVM if it gives you a view to the rear. In order to be able legally to get rid of it, you would need a 100% opaque tint on the rear window (which actually may also be illegal) or a solid bulkead between the driver and the rear of the vehicle.
It's hard to tell from the angle of the photo, but does that screen block your view of any of the swept area of the glass? The law only allows a maximum 40mm intrusion into the swept area of the windscreen, which is one of the restirctions I am finding causes problems. Technically anything over 40mm is not allowed and is an MOT failure.
Post #596678 27th Jan 2017 10:47am
Page 2 of 3 <123>
