Home > Technical > 2011 TDCI door lock fail
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Hi, I have just noticed that my near side rear door fails to lock on either the key or remote. I can lock it manually by pushing the button down but it just remains and will not operate. Any ideas what i should look for before i start ripping door cards off?
Thanks in advance!
Post #594965 21st Jan 2017 2:23pm
Hal
Mine did that. Broken wire. Getting the door card off isn't difficult, just be careful not to break the clips. Wait til you get a warm day, everything gets brittle in the cold.
Post #594977 21st Jan 2017 3:19pm
grafty99
+1 for a broken wire, it's a common fault Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #594995 21st Jan 2017 4:20pm
Pinky
Thanks guys, is it likely to be where it enters the door?
Post #595000 21st Jan 2017 4:27pm
ericvv
They all do that indeed (second row doors on 110s). I had my right side rear door wire replaced a good year ago, so that was after 7 years, and the left side wires broke just two months ago and were replaced recently. Probably good again for another 5 years or more now.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #595001 21st Jan 2017 4:27pm
grafty99
Yes in the rubber flex between the door and pillar is a good place to start looking. If not in there then the trim will have to start coming off 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595004 21st Jan 2017 4:29pm
Pinky
Thanks!
Post #595027 21st Jan 2017 5:38pm
rossy
Mine were done a couple of years ago under warranty. With kids the rear doors get used a lot and the constant bending of the thin wire snaps it. The dealer was well aware of this problem and always uses normal electrical flex from a Twin + Earth cable for a more long term fix. He even showed me how to do it myself should it happen again (except I've forgotten Embarassed )
Post #595379 22nd Jan 2017 6:32pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Eh .... any chance you could go to a hypnotist or something? it would be a great fix to know.
Post #595404 22nd Jan 2017 7:17pm
