Home > Maintenance & Modifications > Waterproof surface mount socket
Krissvdh
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi folks,
I'm hoping someone will have done or perhaps knows a little about roof tent electrics.
I'm looking for a two pin version of the pictured socket, or a similar two pin or even three pin, waterproof solution.
Any ideas gratefully received.
Kris
Post #474283 19th Nov 2015 5:39pm
PaulMc
Have a look at this post - http://www.defender2.net/forum/post449301.html#449301 Paul.
Post #474304 19th Nov 2015 6:07pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Go for the Buccaneer connection, The Royal National Lifeboat Institution use them on all their boats from the D class inshore to the lattest Shannon Class Off shore, We NEVER have an issue with them if used correctly. Only issues we get is people not doing up the collar then pulling the connector apart when using search lights or overtighting the dust and thus being a Censored to remove. Handy hint for the dust cover, Its castleated and there is a keyway for it in the Male socket so you put that over the top and turn lot simpler. We also pack outs with GP marine grease.
Post #474310 19th Nov 2015 6:38pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
I was considering same solution for my roof tent. Ended up with cord extension from the cigarette lighter socket. Routing any place through a door (rubber gasket does not damage the cable nor cable do any wrong to closing a door) and through a gap on tent's hinge. Splitter in the tent and all my electrical stuff and lighting works perfect! Janusz
www.yahodeville.com
Post #474313 19th Nov 2015 6:45pm
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Re: Waterproof surface mount socket
Krissvdh wrote:
Hi folks,
Kris
I bought that same connector for my spotlight roof bar. I think its too big and looks a bit pap. Am currently trying to source another sort with a 90Deg connection to keep it low profile. The best I could fins was these...
http://www.bulgin.com/front-panel-mount-co...ocket.html
http://www.bulgin.com/right-angle-overmoul...-plug.html
The entire catalog is here...
http://www.bulgin.com/media/import/Web_Catalogue.pdf
Post #474402 19th Nov 2015 9:54pm
Krissvdh
The Bulgin connectors are exactly what i was looking for thanks chaps. Outstanding result!
Post #474408 19th Nov 2015 10:10pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Did anyone find where to buy you right angle Bulgin Buccaneer plug? RS don't seem to stock them...
Post #593576 16th Jan 2017 7:05pm
Romadog
Post #593595 16th Jan 2017 7:34pm
Yannis
I was hoping sub €100 euros for both male and female parts.
Thanks though
Post #593617 16th Jan 2017 8:24pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Cetane wrote:
Krissvdh wrote:
Hi folks,
Kris
did anyone get both plug and socket? if so, what was the total cost?
cheers Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #593720 17th Jan 2017 2:07am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Romadog wrote:
This maybe of interest ?
https://shop.landreiziger.nl/modificatie/m...frack.html
That's a kit including cables, relay etc to hook up lights. Just the connectors would be cheaper. It's probably a bit hard to find if you don't speak dutch, so here are the actual connectors themselves:
https://shop.landreiziger.nl/waterdichte-connector-kabel-bus.html (plug)
https://shop.landreiziger.nl/bus-met-kabel-4-polig-female.html (plug with 2m cable)
https://shop.landreiziger.nl/waterdichte-c...polig.html (same but at 90 deg)
https://shop.landreiziger.nl/waterdichte-c...ekker.html (socket)
https://shop.landreiziger.nl/waterdichte-c...basis.html (optional 90 degrees mounting piece)
https://shop.landreiziger.nl/waterdichte-c...hting.html (seal)
They are IP67 and max 16A.
You also might want to check the magcode system, which landreiziger has on offer too. Magcode pro can handle 25A. I guess it's not ment to remain connected inn all weather 24/7 but that's just a guess tbh.
https://shop.landreiziger.nl/catalogsearch/result/?q=Magcode
Hope this helps.
Greetings,
Joris
Post #593722 17th Jan 2017 2:55am
dorsetsmith
Krissvdh wrote:
Hi folks,
Kris
http://www.mobilecentre.co.uk/
Post #593769 17th Jan 2017 8:58am
